  PTC Pro/NC
  Survey
Autor Thema:  Survey (545 mal gelesen)
gr83mlr
Mech Engineer
Sehen Sie sich das Profil von gr83mlr an!   Senden Sie eine Private Message an gr83mlr  Schreiben Sie einen Gästebucheintrag für gr83mlr
Pro-E, Pro-MFG, CamPost (PProcessor), Surfcam
erstellt am: 07. Mai. 2003 19:28    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
To all of you
This is a survey for informational purpose.
If you keep your workcoordinate at the same corner you may have Z+ numbers
instead of Z-. Or in other words, is your coordinate system always at the top
of the part. I have seen both 'styles' and know, that there are pro's and
con's to program from the top down or bottom up (Vertical and Horizontal).
Some operators prefer Z- numbers over Z+.
I would like to know who is programming everything top down or who does use
Z+ numbers.
Thank you for your time
TONY JAGER
655 Cedar Street
San Carlos, CA 94070
ph.: 650-591-1295
e-mail: tjager5@sbcglobal.net
          Anton_Jager@hotmail.com
Tony C. Jager
655 Cedar Street
