  MicroStation
  VRML and VBA and Microstation point3d in excel
Autor Thema:  VRML and VBA and Microstation point3d in excel (1116 mal gelesen)
tasnimi
Sehen Sie sich das Profil von tasnimi an!   Senden Sie eine Private Message an tasnimi  Schreiben Sie einen Gästebucheintrag für tasnimi
erstellt am: 28. Okt. 2004 14:56    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Dear Friend!
"Dim MyPoint3D as Point3d" is not posible ! why?
I was able to use every class in VBA under Excel from Microstation 2004(V8) and change some attribute as well. but unfortunately not any POINT3D.
It is amazing because most importatnt thing is Point3D, which is easy to instantiate in VBA under Microstation but it is not possible in VBA under Excel.
My question is, who it couls be possible that you would be able to use a lot of other objects of Microstation CAD under Excel-VBA but not Point3D!!  Point3D is first thing for every geometry
Thank you for the help.
Best regards,
F. Tasnimi
