mir ist dein problem nicht ganz klar. Aber es klingt nach einer Autodesk Map Statusleiste. (Sysinfo bitte ausfüllen!) Eventuell hat es damit zu tun:
Re: Status Bar - Map 2007
There will be technical solution published in the next days under URL http://usa.autodesk.com/getdoc/id=TS1057082
that explains how to change between the AutoCAD and new Map status bar.I'm copying the content below.
Marion Pietsch
Autodesk Product Support
Infrastructure Solutions
To set the Autodesk Map 3D back to the default AutoCAD status bar do the
following:
1. Exit Autodesk Map 3D.
2. Open the Windows Registry Editor.
Warning! Problems caused by improperly editing the Windows registry could
render your computer operating system unusable. Microsoft provides a wealth
of critical information that you need to know about the registry in the
Microsoft Knowledge Base.
Use the Microsoft® Registry Editor only at your own risk and only after
backing up the registry as well as the system.dat and user.dat files as
outlined for your operating system in the Microsoft Knowledge Base and in
the related Autodesk solution, http://support.autodesk.com/getdoc.asp?id=TS66513. Additional information
about the registry is also contained in the Help topics in the Microsoft
Registry Editor.
3. Go to
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.0\ACAD-5002:xyz\Applications\AcMap
(where xyz are numbers and characters that vary depending on the installed
language version of Autodesk Map 3D).
4. Select AcMap and do a right click > New > DWORD Value.
5. Rename the newly created value to Statusbar.
6. As value enter 0.
7. Exit the Windows Registry Editor and launch Map.
To load the Autodesk Map 3D status bar instead of the AutoCAD one, set the
Statusbar value to 1.
Note: You can't switch between the Autodesk Map 3D and AutoCAD status bar on
the fly when Autodesk Map 3D is running.
wrote in message news:5168137@discussion.autodesk.com...
I use the quick keys to turn them on and off, I just find myself not knowing
whether they are on or off, since there isn't an obvious depressed button
anymore.
I can't see much need for more space in the bottom statusbar, I use a 20
inch widescreen and have approx 23cm of totally empty bar at the bottom.
Even a normal 4:3 monitor should have enough space.
The new menu is clumsy as hell.
So far I'm really not impressed with 2007.
