I am facing some Problem while Exporting PDF of a project created with English UK as primary language and Chinese as secondary language . While Generating PDF PDF is generating in English nut for Chinese it gives Msg "The text '备用保险' on page '&EAA/1' contains characters that cannot be displayed with the set font."
i am using Consoles as default fonts for Eplan 2.7 HF6.
EPLAN 3.33 EPLAN 5.xx P8 1.9.6 P8 1.9.10 P8 1.9.11 P8 2.0.9 - 2.8 alle Prof.
erstellt am: 07. Mai. 2019 14:28 <-- editieren / zitieren --> Unities abgeben: Nur für Prince1209
You need to have the fonts also avaible for other window programms like Adobe Reader. Therefor copy all fonts for your Language you need to the windows folder for fonts. Maybe that helps. Have a problem like this with other language and that helps me. Hope it works.
Thanks for your reply.. i tried this option also but its not working.. when i am selecting Microsoft JhengHei font then it is giving only Chinese PDF. i have also added Chinese language on Project Setting for PDF Output language (screenshot attached) but no use..
i don't know what is wrong.. it used to work before in 2.6 version without any specific setting or font selection. but in 2.7 it is giving this problem..
EPLAN Electric P8 2026.0.3 Update 1 (Build 25480) EPLAN Pro Panel Professional Addon EPLAN Fluid Addon
erstellt am: 07. Mai. 2019 15:50 <-- editieren / zitieren --> Unities abgeben: Nur für Prince1209
Which Font Type is set to the project ?
------------------ Der Fuchs ist schlau und stellt sich dumm. Bei vielen ist es andersrum ------------------------------------------ Da lernt man mühevoll laufen und sprechen, und nun soll ich stillsitzen und die Klappe halten !
