  Export Eplan schematics all articles name and connections
Eplan Copilot: KI wird zum verlässlichen Wissenspartner im Engineering , eine Pressemitteilung
Autor Thema:  Export Eplan schematics all articles name and connections (1133 / mal gelesen)
msmsms
Sehen Sie sich das Profil von msmsms an!   Senden Sie eine Private Message an msmsms  Schreiben Sie einen Gästebucheintrag für msmsms
erstellt am: 12. Okt. 2021 12:50    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
entschuldige fuer english, aber fuer mich is leichter and nich lost Thema.
Danke fuer unterschtuzung.
tried to find solution, how to export articles (all schematics articles name + only used connection) - with predefined label type (yet not exist, quered on vendor side).
For this reason I try to specify export requirements.
1. How is possible in project (Eplan Pro Panel v2.9) make an report of all articles which have fullfiled e.g. in atributes line 30?
2. Like point 1., but export to xls,csv or txt?
2A. In exported name_YYMMDD-HHMM, where YYMMDD_HHMM is date/time from export frame?
3. How is possible make an report of all schematics articles, which were added newer like defined date/time?
4. Examples (required for labels printing sw, but only used connection), all components in one report file
4A. K1 (contactor, 3 power lines), how to create export file where are each line
K1 (name)
K1.1 or 1 (first power input)
K1.2 or 2 (first power output)
K1.5 or 5 (third power input)
K1.6 or 6 (third power output)
but export of line only when is connected
Output (K1 with connected 1, 2, 3, 4)
K1, Article/Atribute/Line30
K1.1, Article/Atribute/Line31
K1.2, Article/Atribute/Line31
K1.3, Article/Atribute/Line31
K1.4, Article/Atribute/Line31
4B. X10 (Terminal 2pole, 1..5)
X10 (name)
X10:1 (first terminal input)
X10:1 (first terminal output)
X10:5 (5th terminal input)
X10:5 (5th terminal output)
Output (X10, connected all of 1, 2, input of 4, output of 5, nothing for 3)
X10, Article/Atribute/Line30
X10:1, Article/Atribute/Line31
X10:2, Article/Atribute/Line31
X10:4, Article/Atribute/Line31
X10:5, Article/Atribute/Line31
Thank you very much in advance for all other recommendation ho to realize it.
Elektrokonstrukteur im Anlagenbau (m/w/d)
pepe-perez
Konstrukteur, Elektroplaner, Cunsultant
Sehen Sie sich das Profil von pepe-perez an!   Senden Sie eine Private Message an pepe-perez  Schreiben Sie einen Gästebucheintrag für pepe-perez
Eplan 5.70
Eplan P8 Prof. Elektrik 2.9.4
Win 10 Pro
Microsoft 365
erstellt am: 21. Okt. 2021 18:34    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für msmsms 10 Unities + Antwort hilfreich
Hello msmsms
It's more than just one question, but of course they belong together.
First of all, we'll look at the steps you need to take.
We'll look at the details later, if there are still questions.
1. You mean Field 30 on Parts, isn't it? Create a new report template and use a filter that's based on this Field.
2. Like point 1...
2A. You mean the name of the file? Should be possible. But I must check it first.
4. I would recommend an Excel output for this. After that, the data can be imported into any Excel template and the design takes over the template. So it is a simple export. This is possible.
If there is an exact template, you can export directly into it. One step less to do.
4A This should be a label for the connections, rigth? Also an Excel export. I have not done so yet, but think that it should work in general.
Should a text be issued afterwards?
Example would look more like this:
-K1    Text
-K1:A1 Text
-K1:A2 Text
-K1:13 Text
BR
Pepe
Du merkst das Du erwachsen bist, wenn die Monster unter deinem Bett, in deinen Briefkasten umgezogen sind.
