| | |  | MuM Material Browser für Inventor , eine App
Thema: Problem mit SelectEvent (1965 mal gelesen)
yamaha Mitglied Konstrukteur
 Beiträge: 384 Registriert: 19.05.2004 Autocad/Inventor 2019, Windows 7 Pro 64Bit
erstellt am: 20. Feb. 2008 20:48 <-- editieren / zitieren --> Unities abgeben:
Hallo zusammen, Für das SelectEvent gibt es als Beispiel nachfolgenden Code: Auf VB6 funktioniert das ja auch recht schön, nur leider in .Net eben nicht. Code:
' The declarations and functions below need to be copied into ' a class module whose name is "clsSelect". The name can be ' changed but you'll need to change the declaration in the ' calling function "TestSelection" to use the new name.' Declare the event objects Private WithEvents oInteractEvents As InteractionEvents Private WithEvents oSelectEvents As SelectEvents ' Declare a flag that's used to determine when selection stops. Private bStillSelecting As Boolean Public Function Pick(filter As SelectionFilterEnum) As Object ' Initialize flag. bStillSelecting = True ' Create an InteractionEvents object. Set oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents ' Ensure interaction is enabled. oInteractEvents.InteractionDisabled = False ' Set a reference to the select events. Set oSelectEvents = oInteractEvents.SelectEvents ' Set the filter using the value passed in. oSelectEvents.AddSelectionFilter filter ' Start the InteractionEvents object. oInteractEvents.Start ' Loop until a selection is made. Do While bStillSelecting DoEvents Loop ' Get the selected item. If more than one thing was selected, ' just get the first item and ignore the rest. Dim oSelectedEnts As ObjectsEnumerator Set oSelectedEnts = oSelectEvents.SelectedEntities If oSelectedEnts.Count > 0 Then Set Pick = oSelectedEnts.Item(1) Else Set Pick = Nothing End If ' Stop the InteractionEvents object. oInteractEvents.Stop ' Clean up. Set oSelectEvents = Nothing Set oInteractEvents = Nothing End Function Private Sub oInteractEvents_OnTerminate() ' Set the flag to indicate we're done. bStillSelecting = False End Sub Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) ' Set the flag to indicate we're done. bStillSelecting = False End Sub
Weiß jemand wo der Haken ist? ------------------ Gruß Jörn
[Diese Nachricht wurde von yamaha am 21. Feb. 2008 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
daywa1k3r Ehrenmitglied V.I.P. h.c. Softwareentwickler
 Beiträge: 3497 Registriert: 01.08.2002 Desktop: 3.3GHz;8GB;SSD OCZ Vertex 3;Gainward Phantom GTX570 Laptop: Alienware m17x Win7, Inventor2012
erstellt am: 20. Feb. 2008 22:57 <-- editieren / zitieren --> Unities abgeben:          Nur für yamaha
erstellt am: 20. Feb. 2008 23:12 <-- editieren / zitieren --> Unities abgeben:
Hallo Igor, ich habe eine dll erstellt und somit kann ich nicht debuggen (VB.Net Express). Ich weiß ehrlich auch nicht wo der Fehler ist. Ich rufe oSelect.Pick(... ) usw. auf, aber man kann nichts auswählen/select. Sorry für die einfache Beschreibung, aber anders weiss ichs auch nicht. Ich hatte angenommen, das das Beispiel als solches für .Net evtl. nicht korrekt ist, und jemand der halt so eine Selection bereits verwendet direkt weiß wo es haken kann. ------------------ Gruß Jörn Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 20. Feb. 2008 23:32 <-- editieren / zitieren --> Unities abgeben:          Nur für yamaha
erstellt am: 21. Feb. 2008 22:01 <-- editieren / zitieren --> Unities abgeben:
Hallo Igor, da hast Du recht, so funktioniert es: Code:
Imports Inventor Imports System.Runtime.InteropServicesPublic Class clsSelect ' Declare the event objects Private WithEvents oInteraction As InteractionEvents Private WithEvents oSelect As SelectEvents ' Declare a flag that's used to determine when selection stops. Private bStillSelecting As Boolean Public Function Pick(ByVal filter As SelectionFilterEnum, ByVal oAppOselect As Application) As Object ' Initialize flag. bStillSelecting = True ' Create an InteractionEvents object. oInteraction = oAppOselect.CommandManager.CreateInteractionEvents ' Define that we want select events rather than mouse events. oInteraction.SelectionActive = True ' Set a reference to the select events. oSelect = oInteraction.SelectEvents ' Set the filter using the value passed in. oSelect.AddSelectionFilter(filter) ' The InteractionEvents object. oInteraction.Start() ' Loop until a selection is made. Do While bStillSelecting System.Windows.Forms.Application.DoEvents() Loop ' Get the selected item. If more than one thing was selected, ' just get the first item and ignore the rest. Dim oSelectedEnts As ObjectsEnumerator oSelectedEnts = oSelect.SelectedEntities If oSelectedEnts.Count > 0 Then Pick = oSelectedEnts.Item(1) Else Pick = Nothing End If ' Stop the InteractionEvents object. oInteraction.Stop() ' Clean up. oSelect = Nothing oInteraction = Nothing End Function Private Sub oSelect_OnSelect( _ ByVal JustSelectedEntities As Inventor.ObjectsEnumerator, _ ByVal SelectionDevice As Inventor.SelectionDeviceEnum, _ ByVal ModelPosition As Inventor.Point, _ ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles oSelect.OnSelect bStillSelecting = False End Sub End Class
Ich versteh bloß nicht wieso ich das oAppOselect übergeben muß. Das muß doch irgendwie auch als globe Variabele deklariert werden können?
erstellt am: 21. Feb. 2008 23:18 <-- editieren / zitieren --> Unities abgeben:          Nur für yamaha
Hallo Jörn, in .NET gibt es so etwas wie globalen Variablen nicht, denn .NET basiert auf der Kapselung. Eine Klasse soll eine Einheit mit klar definierten Schnittstellen sein. Wenn du in einer Klasse ein Objekt brauchst, musst du es entweder instanzieren oder als Argument übergeben. In dem Fall der clsSelect ist der Weg über die Argumente der bessere, denn es wäre trotz automatischer Ressourcen-Bereinigung schwachsinnig jedes mal ein neues Inventor Objekt zu instanzieren sobald die Funktion aufgerufen wird. Es wäre natürlich möglich ein privates Datenfeld zu definieren, und einen Konstruktor der bei der sich bei der Instanzierung von der Klasse ein Inventor Objekt holt und den behält. Die untere Funktion könnte dann auf das Objekt zugreifen, da es ein privates Datenfeld von der gleichen Klasse ist. Man könnte den Konstruktor auch überladen und um ein Argument von Typ InventorApplication erweitern, so dass bei der Neuinstanzierung von der Klasse ein InventorObjekt übergeben werden kann. In dem Fall erhält das private Datenfeld das Inventor Objekt, und zwar ohne eine Neuinstanzierung. Da wäre dann dieses private Datenfeld eine Art von globalen Variable, aber eben nur für die Mitglieder der gleichen Klasse. Ganz davon abgesehen, dass in der Klasse eigentlich nur der CommandManager von dem Inventor-Objekt benutzt wird, so würde es auch reichen nur den CM zu übergeben. Usw. usf. Genau so wie bei dem Umstieg von Autocad auf Inventor, wo man fast alles aus dem Autocad vergessen sollte, ist es auch bei dem Umstieg von VB bzw. VBA auf .NET. Ganz von der Syntax abgesehen, ist auch das ganze Konzept völlig anders. Aber schon mal Lob, dass du es mit VB.NET zum Laufen gebracht hast.
------------------ Grüße Igor FX64 Software Solutions Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 22. Feb. 2008 12:09 <-- editieren / zitieren --> Unities abgeben:
Hallo Igor Zitat: Es wäre natürlich möglich ein privates Datenfeld zu definieren, und einen Konstruktor der bei der sich bei der Instanzierung von der Klasse ein Inventor Objekt holt und den behält. Die untere Funktion könnte dann auf das Objekt zugreifen, da es ein privates Datenfeld von der gleichen Klasse ist. Man könnte den Konstruktor auch überladen und um ein Argument von Typ InventorApplication erweitern, so dass bei der Neuinstanzierung von der Klasse ein InventorObjekt übergeben werden kann. In dem Fall erhält das private Datenfeld das Inventor Objekt, und zwar ohne eine Neuinstanzierung. Da wäre dann dieses private Datenfeld eine Art von globalen Variable, aber eben nur für die Mitglieder der gleichen Klasse. Ganz davon abgesehen, dass in der Klasse eigentlich nur der CommandManager von dem Inventor-Objekt benutzt wird, so würde es auch reichen nur den CM zu übergeben. Usw. usf.
Besten Dank für die Erklärung auch wenn ich den zweiten Teil nicht versteh, aber.. Zitat:
hilft schon. ------------------ Gruß Jörn Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 26. Feb. 2008 22:30 <-- editieren / zitieren --> Unities abgeben:
Hallo, leider mußte ich feststellen, das obiger Code doch nicht so ganz gut funktioniert. 1. In einer Exe und externer Zugriff auf Inventor: Alles OK 2. In einer DLL und in Inventor eingebunden: Wenn man auswählt wie vorgesehen dann OK, aber!!! Bricht man den Selection-Vorgang mit ESCAPE ab, stürzt Inventor bei irgend einer der nächsten Aktionen ab. Irgendwie wird das Abbrechen des Selection nicht sauber beendet. Schade, also wenn jemand noch einen Tip hat. Desweiten, noch ein zweiter Effekt der aufgefallen ist. Beim Abbrechen oder Beenden von einer Funktion wird der Button nicht zurück gesetzt (Pressed = false). Auch hier, vielen Dank für einen Tip.
erstellt am: 26. Feb. 2008 22:42 <-- editieren / zitieren --> Unities abgeben:          Nur für yamaha
Hi Jörn, benutze mal Fehlerbehandlung nach der Loop. Möglich, dass oSelect.SelectedEntities eine Exception wirft sobald nichts selektiert wurde. Zitat: Original erstellt von yamaha: Desweiten, noch ein zweiter Effekt der aufgefallen ist. Beim Abbrechen oder Beenden von einer Funktion wird der Button nicht zurück gesetzt (Pressed = false).
Wenn die Funktion abstürzt und keinen Wert zurückgibt, denkt Inventor, dass der Befehl weiter läuft und hat keinen Grund den Button zurück zu setzen. ------------------ Grüße Igor
erstellt am: 27. Feb. 2008 09:04 <-- editieren / zitieren --> Unities abgeben:
Hallo Igor, Zitat: benutze mal Fehlerbehandlung nach der Loop
Ich hatte schon mit Try... vor dem Loop versucht, hab auch eine Fehlermeldung bekommen, abgestürzt ist Inventor aber trotzdem. Werd nochmal etwas testen und weitere Info geben. Zitat: Wenn die Funktion abstürzt und keinen Wert zurückgibt, denkt Inventor, dass der Befehl weiter läuft und hat keinen Grund den Button zurück zu setzen.
Das wäre logisch, aber "Beim Abbrechen oder Beenden von einer Funktion....." Also läuft der Befehl ganz normal durch, bleibt der Button auch "gepresst". Beim nächsten Aufruf/Klick geht er dann auf "nicht gepresst" Werd das nochmal mit einer ganz einfach Routine überprüfen. ------------------ Gruß Jörn Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
| Anzeige.:
