  WSCAD V5.x
  Project structure in Wscad 5.1 - partial solution
WSCAD AI Engineer Training in Stuttgart, ein Seminar am 16.11.2026
Autor Thema:  Project structure in Wscad 5.1 - partial solution (620 mal gelesen)
Larin Croft
Sehen Sie sich das Profil von Larin Croft an!   Senden Sie eine Private Message an Larin Croft  Schreiben Sie einen Gästebucheintrag für Larin Croft
erstellt am: 22. Mai. 2008 21:39    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
FoldersstructureforWscad5_1.pdf
Hi fiends,
I am starting with Wscad.
But Wscad Project management is for nothing I mean (horrible tool), only for Wscad SW engineers maybe.
I asked the question about folders in Wscad 5.1 in this forum. I didn’t get reasonable reply I mean.
So, I did something. Now I put it to you what I done.
robroy55
Elcad V5/V7 Prof.
Eplan V5/P8 Prof.
Sigraph(SPEL-D) V5/V8/V9/V10
Wscad V4/V5/Suite Prof.
Ruplan V4.7/V4.8 Std/EVU
Autocad LT 2007
erstellt am: 30. Mai. 2008 15:03    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Larin Croft 10 Unities + Antwort hilfreich
Hi Larin Croft,
some people buy a car and then they pushed it by manpower from point A to point B!
I mean the place where the parts are build in is not so important. More important for me is the function. I want to see what a part of control is duing not where it is build in.
In the last 20 years i build many plant or machine controls. Some of them had functions over 2 or 3 cubicles. In your sight i have to search in 2 or 3 circuit diagrams to see the whole function. That is not good, but if it is good for you, ok, do it!
But think about that. If i would be a customer of you and you send me a circuit diagram structure like that, i would it send back and say build it in normal way, like WSCAD has it engineered. I dont want to change my properties all the time if i want to see the different cubicles. Some other engineers see it the same way, i think!
Grüße aus Frangn
Rob
Je mehr Käse, desto mehr Löcher. Je mehr Löcher, desto weniger Käse. Also: Je mehr Käse, desto weniger Käse! ODER? (Aristoteles)
