  Alibre Design
  SimLab Composer V2
Autor Thema:  SimLab Composer V2 (1175 mal gelesen)
Ralf Schrödter
Konstruktion & Support
-> Windows 11- 64 bit
-> i9 / Nvidia RTX
-> Alibre-Design V28.1.1
-> Moi3D V4
-> KeyShot V13
erstellt am: 06. Apr. 2010 18:35    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Für 117,- Euro, das muss ich einfach posten.
SimLab Composer is an interactive 3D scene building application, which allows the user to combine geometries from different sources (MCAD/CAD and visualization applications) to build 3D scenes.
3D scenes created in SimLab Composer can be exported to many popular file formats including 3D PDF.
The new release of SimLab Composer adds KeyShot (bip) format to the export options, which will enable KeyShot users to take advantage of its 3D scene building capabilities.
In addition to the simple to use rotate, pan and zoom draggers, SimLab Composer provides the user with snap to ground and snap to object utilities, which makes creating 3D scenes easy and fun.
The user of SimLab Composer is able to create copies and instances of existing parts and assemblies in the scene.
SimLab Composer’s ability to maintain CAD tree structure makes it easy for the user to Hide/Show parts, assemblies, and sub assemblies.
SimLab Composer enables users to perform advanced material management, which includes changing the material structure, and controlling material assignment on the surface, body, part and assembly levels.
To learn more about SimLab Composer scene building capabilities please click here
To learn more about SimLab Compose please visit SimLab Soft
SimLab Composer is supported on Windows and Mac
Multiple 3D Format Support
Designed to be the ultimate 3D sharing tool, SimLab composer supports many of the widely used 3D formats, including:
SketchUp, Rhino, STEP, IGES, Collada, 3D PDF, 3D XML from CATIA, FBX, Obj, 3DS, DXF, U3D, STL, SolidWorks*, and DWG*
* Nur für Windows
SimLab Composer supports exporting different formats for sharing 3D scenes, those format include 3D PDF, WaveFront (obj), Collada, FBX, KeyShot (bip), STL, OSG and IVE. SimLab Composer enables the user to pack the 3D scene with all its textures in one zip file that can be used on different machines.
...usw.
Gruß Ralf
www.alibre.info
Micha Knipp
Werkzeugmacher
P53
SpaceNavigator
Alibre V28
FreeCad 1.1
erstellt am: 06. Apr. 2010 19:58    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Ralf Schrödter 10 Unities + Antwort hilfreich
Hallo Ralf,
Danke für die Info. Toll, wie einfach manche Dinge gehen können.
Gruß aus Leverkusen
Micha Knipp
Ralf Schrödter
-> i9 / Nvidia RTX
-> Moi3D V4
-> KeyShot V13
erstellt am: 06. Apr. 2010 20:14    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hallo Micha,
was mich absolut fasziniert, abgesehen von den vorhandenen Importmöglichkeiten, man kann vorhandene, also z.B. aus Alibre erstellte 3D PDF Dateien, im Composer mit anderen Dateiformaten zusammenführen und rendern, exportieren, Szenen zusammenstellen, verschiedene Beleuchtungen, Hintergründe...ich wollte es zuerst nicht glauben.
Für 117,- Euro und mit der Möglichkeit auf zwei Rechnern zu installieren...
Als ich dann auch noch die einzelnen Teile der importierten 3D PDF Datei/Baugruppe im Composer nachträglich bewegen konnte, habe ich die Info hier gepostet.
Für mich ist das der "Hammer" für den geringen Preis.
Gruß Ralf
www.alibre.info
