  Solid Edge
  Maintenance Pack 11 für Solid Edge 2022 ist verfügbar
Simulation Diskussionsrunde | monatlich Termin: in 9 Tagen
Autor Thema:  Maintenance Pack 11 für Solid Edge 2022 ist verfügbar (1460 / mal gelesen)
Stahlformer
Sehen Sie sich das Profil von Stahlformer an!   Senden Sie eine Private Message an Stahlformer  Schreiben Sie einen Gästebucheintrag für Stahlformer
SE2024 / WIN10Pro64
i5-9600K
P2000
32GB Ram
erstellt am: 20. Dez. 2022 15:14    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Solid Edge 2022 - Maintenance Pack 11 Announcement
December 19, 2022
Dear Solid Edge Customer:
Solid Edge 2022 Maintenance Pack 11 is now available for download.
We appreciate your continued business and participation in the software support process - - your reporting helps us make Solid Edge more productive for how you do business.
Sincerely,
The Solid Edge Team
Release Notes:
Solid Edge 2022 MP11
Version: 222.00.11.02
Solid Edge 2022 Maintenance Packs are delivered using Microsoft Installer (MSI) technology.
Support Center: https://support.sw.siemens.com
Email Notification:
To receive direct email notifications for Solid Edge Maintenance Packs, navigate to your Support Center profile:
https://account.sw.siemens.com/profile, scroll down to Newsletter Subscriptions, then check the box for
Software Field Bulletin.
This Maintenance Pack addresses the following PRs:
===API===
PR 224993: Added new APIs to control the placement of adjustable Assembly and tubes
===Assembly===
PR 10327602: Software crash on Simplify Assembly
PR 10386139: Search and replace did not always show parts that were overridden
PR 10465397: Simplify with Visible Faces command fails
PR 10477532: Pipes did not pull in parent part face styles
PR 10488357: Reorder is slow when multiple occurrences are selected
PR 10500036: User not able to mirror/pattern Material addition features
PR 10419827: Escape key doesn't Finish sketch command in Assembly
PR 10438783: Adjustable Tubes are not staying on paths
PR 10460398: Copy of a component with Mate containing Range values ending up at the wrong position
PR 10461216: Wrong physical properties if "in place editing" subassemblies
PR 10492211: Bad start performance of pathfinder/Standard Parts
PR 10500461: Pipes do not show up in the correct length when parts are made inactive
PR 10502176: Selecting inactive parts in [Match Coordinate Systems] results in an error
PR 8621544: Crash in GeomInspector in V222MP10
PR 8615893: Pathfinder contents disappear after selecting multiple items when "auto-scroll to selected part" is set
===Draft===
PR 10224669: Alternate position settings get lost on drawing views, although inactive
PR 10499968: Weld symbol - identification line is wrong, has to be dashed, regression
PR 10466636: Offset 2D cause Solid Edge to freeze
PR 10517082: Solid Edge shuts down when using Edge Painter
===General===
PR 10377203: Random aborts when Windows 'Use text cursor' setting is "On".
PR 10484530: Can't select any surfaces with the "define" command in Simulation
===Part/Profile/Sheetmetal===
PR 10460889: Cannot edit tangency on a 3D curve (3D sketch) - SE will crash
PR 10488476: "Part Painter" - Resetting face colors after five selections
PR 10472052: Existing custom properties are overwritten by the exposure of variables
===SEEC===
PR 10393277: Import of second draft file overwrites existing dataset in Teamcenter.
PR 10480893: FOP members cannot be replaced by a new revision.
PR 10504433: Unable to run ATT, ATTI, and SESE with a SolidEdgeClassicPlus license
===Translators===
PR 10441588: IFC Import generates incorrect data
PR 10442368: Inventor Data Migration Error
PR 10502339: DWG translation fails
This content is a preview of a link.
Solid-Man66
Sehen Sie sich das Profil von Solid-Man66 an!   Senden Sie eine Private Message an Solid-Man66  Schreiben Sie einen Gästebucheintrag für Solid-Man66
Solid-Edge 2023 MP-10
Inventor 2014 Standard
WIN-10 64 Bit
Saarländer
erstellt am: 21. Dez. 2022 06:06    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Stahlformer 10 Unities + Antwort hilfreich
habe gestern installiert,
bei XpresRoute Markierung Kette funktioniert immer noch nicht richtig.
