  Creo Elements/Direct
  [English] Questions about BOM management (no MM)
Autor Thema:  [English] Questions about BOM management (no MM) (1166 mal gelesen)
cacciatorino
Sehen Sie sich das Profil von cacciatorino an!   Senden Sie eine Private Message an cacciatorino  Schreiben Sie einen Gästebucheintrag für cacciatorino
Solid Edge ST10 Win10-64
Modeling V20.5 Win10-64
Salome 9.1
erstellt am: 03. Apr. 2015 09:59    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Dear collegues, first of all I apoligize if the questions were already discussed here on cad.de: I did a quick search and I didn't find any answer, may be due to the lack of knowledge of german language.
Here are the questions:
1) I need to create the BOM for a certain assembly (no model-manager, just Modeling 18.1 standard). The well known problem is how to manage the groups that need to be exploded (phantom groups) and the ones that need to be cosidered as single item (welded or purchased parts). I made a test with the "indivisble assy" but it does not work. We all know that Modeling is unable to do this, is there any macro that allows to override this limit?
2) I could have the possibility to use Solid Edge to create these boms (solid Edge has a very good control on BOMs): is it possible to export to STEP assigning to each part the model name instead ot the instance name?
3) I need to export BOM to Excel too. I'm doing it with the macro "table_export_dia". Is there a way to customize the format of the exported table? The in-line help states that it is possible, but I don't find the source lisp file.
thank you for your attention.
sebak
Sehen Sie sich das Profil von sebak an!   Senden Sie eine Private Message an sebak  Schreiben Sie einen Gästebucheintrag für sebak
erstellt am: 26. Mai. 2015 16:08    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für cacciatorino 10 Unities + Antwort hilfreich
Dear cocciatorino.
I am not sure what you mean with "Phantom Groups", but we are working with the BOM Assistant from Klietsch.
http://www.klietsch.com/klietsch/store/details.php?lang=uk&source=apps&class=1&type=1&prod_id=29&sel=1
This tool allows us to manage our BOM's without Model Manager and we are also able to export to Excel.
Hope you will find a solution
