  Creo Elements/Direct
  Pipe Fillet Welds
SF FREETOOLS , eine App
Autor Thema:  Pipe Fillet Welds (1249 mal gelesen)
CSPalmer84
Illustrator, Programmer
Sehen Sie sich das Profil von CSPalmer84 an!   Senden Sie eine Private Message an CSPalmer84  Schreiben Sie einen Gästebucheintrag für CSPalmer84
Dell T1700
3.4 Ghz
16 Gb
erstellt am: 10. Dez. 2014 17:14    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello forum
First off, I wanted to say thank you. I'm fairly new to lisp myself, and over the past year this forum has been very helpful in teaching me how PTC does their coding.
Now though, I have come across something that I can not find even here (unless it has been hidden away). As you can see from this picture, I have a swept part that will eventually be a fillet weld. The problem I am having is that I can't find a way to get a consistent flat face on the Green face. Does anyone know how I can slice a part along 2 edges such as this?
The sword itself does not give you courage and strength
CSPalmer84
Dell T1700
3.4 Ghz
16 Gb
erstellt am: 12. Dez. 2014 15:35    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Well, after more discussion and trial and errors we decided to fore go the original idea of sweeping geometry along the weld edge and slicing it somehow and instead used the program against it self.
here are the steps it took to make this happen
Copy both part A and B
Unite CopyA and CopyB
Create a chamfer along the joined edge
Subtract A and B from CopyAB
and you're left with the weld profile.
The sword alone does not give you the courage and strength you will need on your journey
Creo Elements / Direct Modeling version 18.1
Creo Elements / Direct Drafting Version 18.1
