 | Neuer Geschäftsführer bei Software Factory GmbH, eine Pressemitteilung
Thema: [English] Import data from csv table (2447 mal gelesen)
cacciatorino Mitglied
 Beiträge: 49 Registriert: 15.01.2008 Solid Edge ST10 Win10-64 Modeling V20.5 Win10-64 Salome 9.1
erstellt am: 25. Apr. 2010 10:03 <-- editieren / zitieren --> Unities abgeben:
I'm a solid edge user, and I have to export assemblies and parts to step format, for a customer that use OSD. All is ok for geometries and assemblies jerarchy: it works very well excpet cosmetic threads, but this is not a big problem. My solid edge parts and assemblies have all custom properties filled in (material , description, code, surface treatment, etc.) but of course all these data are lost when exporting to step. I can create a table in excel or csv format with there properties, but is there a fast and effective way to import these properties into the corresponding part in the pkg file? Keep in mind that every assemply can be built by several hundreds part. I attach a test file. Best regards, Alessandro. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 25. Apr. 2010 11:03 <-- editieren / zitieren --> Unities abgeben:
highway45 Moderator Bastler mit Diplom
 Beiträge: 6389 Registriert: 14.12.2004 SolidDesigner-20.8.0 + PhoenixPDM-11 + PE-8 + Blender-2.79
erstellt am: 25. Apr. 2010 11:07 <-- editieren / zitieren --> Unities abgeben:          Nur für cacciatorino
erstellt am: 25. Apr. 2010 13:53 <-- editieren / zitieren --> Unities abgeben:
Zitat: Original erstellt von highway45: No Problem cacciatorino !I can not help at your special problem, but some of the collegues here will, I guess. Do you know the international forum ? http://cocreateusers.org/forum/
thank you for answering! In the meanwhile, I downloaded OSD-PE to make some testing, but I discovered that I'm not able even to create a simple custom property on a part, such as a new field named "surface treatment". I will try to study more! Thank for the link, I didn't know it before, I will go to look for something useful there. Best Regards. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 25. Apr. 2010 14:38 <-- editieren / zitieren --> Unities abgeben:
Walter Geppert Moderator Frank und Frei
 Beiträge: 2177 Registriert: 12.12.2000 Konstruktion von Sondermaschinen, Montageautomaten, Meß- und Prüfeinrichtungen, Vorrichtungen und Produktentwicklung mit Creo Elements/Direct Modeling 20.8, AdvancedDesign, Surfacing, SolidPower, ModelManager auf HP ZBook Fury 16 G9, Windows 11 Pro 64
erstellt am: 25. Apr. 2010 16:18 <-- editieren / zitieren --> Unities abgeben:          Nur für cacciatorino
Hi Alessandro, OSD may be customized to the customers need to assign various attributes to parts, assemblies or other items, including density, color, transparency and reflectance. There are several packages from OEMs to support these features, also in connection with data management and it depends on which package -if any- your customer uses. Of course it is possible to write a LISP-script, which will read a csv-file and assign attributes to the model structure. Since there are so various possibilities of additional informations concerning part properties and technological features and in which way they should be attached to the model, a function like this could not be standard functionality of OSD ------------------ meine LISP-Makros sind auf osd.cad.de Disclaimer Grüße aus Wien Walter DC4 Technisches Büro GmbH Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 27. Apr. 2010 16:51 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 28. Mai. 2010 18:31 <-- editieren / zitieren --> Unities abgeben:
