  TM - Plant Simulation
  Problem when exporting to Excel.
Autor Thema:  Problem when exporting to Excel. (1013 mal gelesen)
Maarten
Sehen Sie sich das Profil von Maarten an!   Senden Sie eine Private Message an Maarten  Schreiben Sie einen Gästebucheintrag für Maarten
erstellt am: 12. Okt. 2006 22:20    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello,
I'm sorry for the language but I don't speak German and I couldn’t find an eM-Plant forum in my own language. But I really hope someone can help me.
I got the following problem. When I export data from a tablefile to an Excel file with the function ‘WriteExcelFile’ it will put the data in an Excel file with the correct layout (colours etc.). But when I put data from a second run in the same excel file on a new sheet, the new sheet has the correct layout but the layout of the old sheet is suddenly gone.
This problem continues when I put another sheet with data in the Excel file. Then the layout of the second sheet is also gone. Does anybody know what I can do about it?
I also have another question. Is there a function in eM-Plant which gives the path to the project file it is currently running from? So for instance, a function that gives the string “C:\Program Files\Projects\Project.spp” back if the program is currently running the Project.spp file?
I hope someone can help me with these problems. I spend days trying to find a solution and I’m really getting frustrated.
Thank you very much for reading!
Greetings, Maarten.
erstellt am: 13. Okt. 2006 10:23    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat
What´s your eM-Plant-version  ?
...Is there a function in eM-Plant which gives the path to the project....
There´s a method called "modelfile", which returns the full path -including filename.
Der Simulator
Maarten
erstellt am: 13. Okt. 2006 11:13    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Original erstellt von Simulator:
My version is 7.0
Thank you very much. That's exactly what I needed.
Entwicklungsingenieur (w/m/d) Maschinenbau
Wir sind Winterhalter, der Spülspezialist aus Meckenbeuren. Mit über 2.000 Mitarbeitern an über 40 Standorten in aller Welt gehören wir zu den Marktführern der Großküchentechnik. Tag für Tag arbeiten unsere Mitarbeiter am perfekten Spülergebnis. Gehen neue Wege. Setzen Standards im Markt und begeistern Kunden.
Als Entwicklungsingenieur (w/m/d) Maschinenbau übernehmen Sie eine zentrale Rolle in der Entwicklung unserer gewerblichen Geschirrspülmaschinen....
Anzeige ansehenMaschinenbau
erstellt am: 13. Okt. 2006 16:52    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat
seems you´re right !
exporting from 7.x to XL influences the format of the other XL-sheets.
In my opinion, this is now a case for the eM-Plant-SW-support.
Der Simulator
