  PTC Creo Elements/Direct Model Manager
  [English] Multisite setup
Autor Thema:  [English] Multisite setup (852 mal gelesen)
cacciatorino
Sehen Sie sich das Profil von cacciatorino an!   Senden Sie eine Private Message an cacciatorino  Schreiben Sie einen Gästebucheintrag für cacciatorino
Modeling + MM V20.1 Win10-64
erstellt am: 02. Nov. 2011 07:26    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Me and my customer are trying to setup properly a multisite installation of Model Manager.
the system works, more or less, but we are investigating to solve two issues:
1) when I (down)load an assembly from my customer server (he has the Oracle DB server) the first operation is always very slow (about 20 minutes for a 5 MB pkg-equivalent). This is normal, no questions at all. The problem is that the system needs the same time even at the second or third opening of the same assembly, even if I can see that the storage area on my server was already populated with the cripted files from the first attempt.
2) how is it possibile to force a sync, either by hand or as scheduled task?
Thank you for reading.
mfg, Alessandro.
