ich habe gerade 1 datei erfolgreich in Baugruppe geladen.
Nun würde ich gerne 2 Datei gleichzeitich in einer Baugruppe
laden. Deswegen habe ich einen Beispiel von Hilfe von API probiert.
Es kommt ein paar meldung. Irgendwie probiert, aber folgt immer
andere Meldung.
wie kann ich tun?
Gruss von stuttgart
macro
Dim swApp As Object
Dim Part As Object
Dim count As Long
Dim startX As Double, startY As Double, startZ As Double
Dim incrX As Double, incrY As Double, incrZ As Double
Dim compScale As Double, incrScale As Double
Dim index1 As Integer, index2 As Integer
Dim listSize As Integer, listIndex As Integer
Dim compNames() As String
Dim compXforms() As Double
Dim vcompNames As Variant
Dim vcompXforms As Variant
Dim vcomponents As Variant
Sub main()
' Get the number of components to add
count = Val(txtCompCount.Text)
If (count < 1) Then
Exit Sub
End If
' Number of unique component filenames to add
listSize = lstCompNames.ListCount
ReDim compNames(count - 1)
ReDim compXforms(count * 16 - 1)
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
' Should make sure this is an Assembly document
' For each component to be added, create a separate transform
If (Not Part Is Nothing) Then
For i = 1 To count
index1 = i - 1
index2 = (i - 1) * 16
' Components can be added multiple times, transforms cannot
listIndex = index1 Mod listSize
compNames(index1) = lstCompNames.List(listIndex)
' Fill in the rotation component of the transform
compXforms(index2) = Val(txtCompOrient(0).Text)
compXforms(index2 + 1) = Val(txtCompOrient(1).Text)
compXforms(index2 + 2) = Val(txtCompOrient(2).Text)
compXforms(index2 + 3) = Val(txtCompOrient(3).Text)
compXforms(index2 + 4) = Val(txtCompOrient(4).Text)
compXforms(index2 + 5) = Val(txtCompOrient(5).Text)
compXforms(index2 + 6) = Val(txtCompOrient(6).Text)
compXforms(index2 + 7) = Val(txtCompOrient(7).Text)
compXforms(index2 + 8) = Val(txtCompOrient(8).Text)
' Add the translation component of the transform
compXforms(index2 + 9) = Val(txtCompX.Text) + (index1 * Val(txtCompIncrX.Text))
compXforms(index2 + 10) = Val(txtCompY.Text) + (index1 * Val(txtCompIncrY.Text))
compXforms(index2 + 11) = Val(txtCompZ.Text) + (index1 * Val(txtCompIncrZ.Text))
' Add the scale component of the transform
compXforms(index2 + 12) = Val(txtCompScale.Text) + (index1 * Val(txtCompIncrScale.Text))
Next i
' Add the components to the assembly.
vcompNames = compNames
vcompXforms = compXforms
vcomponents = Part.AddComponents((vcompNames), (vcompXforms))
End If
End Sub
