  CATIA V5 Programmierung
  catpart saveas 3dxml
Autor Thema:  catpart saveas 3dxml (643 / mal gelesen)
Sylas
Sehen Sie sich das Profil von Sylas an!   Senden Sie eine Private Message an Sylas  Schreiben Sie einen Gästebucheintrag für Sylas
Dell Precision T3500
Intel Xeon W3550 @ 3,07 GHz
12 GB RAM
CATIA V5 R28
erstellt am: 09. Mrz. 2026 13:38    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello
I would like to create a macro which for each catpart found in source folder (pointed by user) saves it as 3dxml, preferrably under subfolder "3DXML" created under source folder
What would be the solution?
So far I have (AI generated):
Code:
Function PickFolderDialog(prompt As String) As String
    Dim objShell As Object
    Dim objFolder As Object
    Set objShell = CreateObject("Shell.Application")
    Set objFolder = objShell.BrowseForFolder(0, prompt, 0, 0)
    If Not objFolder Is Nothing Then
        PickFolderDialog = objFolder.Self.path
    Else
        PickFolderDialog = ""
    End If
End Function
Sub ExportCATPartsTo3DXML()
    Dim sourceFolder As String
    Dim targetFolder As String
    Dim fileName As String
    Dim prodDoc As ProductDocument
    Dim catPart As Document
    '--- pick source folder ---
    sourceFolder = PickFolderDialog("Select folder with CATPart files")
    If sourceFolder = "" Then Exit Sub
    If Right(sourceFolder, 1) <> "\" Then sourceFolder = sourceFolder & "\"
    '--- create 3DXML folder ---
    targetFolder = sourceFolder & "3DXML\"
    If Dir(targetFolder, vbDirectory) = "" Then MkDir targetFolder
    '--- loop CATPart files ---
    fileName = Dir(sourceFolder & "*.CATPart")
    If fileName = "" Then
        MsgBox "No CATPart files found"
        Exit Sub
    End If
    Do While fileName <> ""
        'Open CATPart
        Set catPart = CATIA.Documents.Open(sourceFolder & fileName)
        'Create temporary product
        Set prodDoc = CATIA.Documents.Add("Product")
        prodDoc.Product.Products.AddComponent catPart
        'Export 3DXML
        Dim xmlPath As String
        xmlPath = targetFolder & Replace(fileName, ".CATPart", ".3dxml")
        prodDoc.ExportData xmlPath, "3DXML"
        'Close docs
        catPart.Close
        prodDoc.Close
        fileName = Dir()
    Loop
    MsgBox "3DXML export completed!", vbInformation
End Sub
but it gives me an error "type mismatch" in
Code:
rootProd.Products.AddExternalComponent fullPath
line.
AI code seems always too complicated for me, so I thought you guys could advice me how to approach  my problem
Any advice would be appreciated
THanks
Lucas
Sylas
12 GB RAM
CATIA V5 R28
erstellt am: 09. Mrz. 2026 13:54    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
code update:
Code:
Option Explicit
Sub ExportFolder_CATPart_To_3DXML()
    Dim fullPath As String
    Dim doc As Document
    '--- wybór folderu ---
    sourceFolder = PickFolderDialog("Wybierz folder z plikami CATPart")
    If Right$(sourceFolder, 1) <> "\" Then sourceFolder = sourceFolder & "\"
    '--- folder docelowy ---
    targetFolder = sourceFolder & "3dxml\"
    If Dir$(targetFolder, vbDirectory) = "" Then MkDir targetFolder
    '--- iteracja po plikach ---
    fileName = Dir$(sourceFolder & "*.CATPart")
        fullPath = sourceFolder & fileName
        'otwórz dokument *niewidocznie*
        Set doc = CATIA.Documents.Open(fullPath)
        'ścieżka 3DXML
        xmlPath = targetFolder & doc.Name & ".3dxml"
        '--- EXPORT 3DXML ---
        doc.ExportData xmlPath, "3dxml"
        'zamknij dokument bez zapisu
        doc.Close
        fileName = Dir$()
    Loop
    MsgBox "Gotowe. Eksport zakończony.", vbInformation
End Sub
' 64-bit safe FolderPicker (Shell)
    Dim sh As Object, fld As Object
    Set sh = CreateObject("Shell.Application")
    Set fld = sh.BrowseForFolder(0, prompt, 0, 0)
    If Not fld Is Nothing Then PickFolderDialog = fld.Self.path
End Function
it seems working, but I would like to run it in the background, without screen flickering  how to modify it?
bgrittmann
CATIA V5R19
erstellt am: 09. Mrz. 2026 14:07    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Hi Lucas
You could use CATIA.RefreshDisplay = False to not update the screen.
Or start a additional CATIA instance and run the macro there. (see https://catia2.cad.de/index.php/de/tipps-tricks/administration/274-makro-bei-catia-start-ausfuehren)
Regards,
Sylas
12 GB RAM
CATIA V5 R28
erstellt am: 09. Mrz. 2026 14:45    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hi Bernd
Thanks for the Tip.
Unfortunately, my CATIA is being launched with an extra user interface (without access to CATIA shortcut), so I have to try first option.
I'll check and get back with feedback.
Thank you!
Lucas
Sylas
12 GB RAM
CATIA V5 R28
erstellt am: 09. Mrz. 2026 14:49    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
I'm back again
Here's my code:
Code:
Option Explicit
' GŁÓWNY BATCH EXPORT
Sub Export_CATParts_With_Progress()
    Dim files As New Collection
    Dim f As Variant
    Dim doc As Document
    Dim i As Long
    '--- folder 3dxml ---
    '--- zbierz listę plików ---
        files.Add fileName
        fileName = Dir$()
    Loop
    If files.Count = 0 Then
        MsgBox "Brak plików CATPart."
        Exit Sub
    End If
    '--- uruchom progress bar ---
    UF_Progress.LBL_Info.Caption = "Rozpoczynam..."
    UF_Progress.LBL_Bar.Width = 0
    UF_Progress.Show vbModeless
    DoEvents
    '    PRZETWARZANIE WSZYSTKICH PLIKÓW
    For i = 1 To files.Count
        'aktualizacja paska
        UpdateProgress i, files.Count, files(i)
        'pełna ścieżka
        fullPath = sourceFolder & files(i)
        ' ciche otwarcie dokumentu
        CATIA.DisplayFileAlerts = False    'bez alertów
        'ścieżka wynikowa
        'eksport
        'zamknij cicho
        doc.Close
        DoEvents
    Next i
    'zamknij progress bar
    Unload UF_Progress
    CATIA.RefreshDisplay = True
    MsgBox "Zakończono eksport " & files.Count & " plików.", vbInformation
End Sub
'  AKTUALIZACJA PASKA POSTĘPU
Sub UpdateProgress(current As Long, total As Long, fileName As String)
    Dim percent As Double
    percent = current / total
    With UF_Progress
        '.LBL_Info.Caption = "Przetwarzanie: " & vbNewLine & fileName & _
                            "  (" & current & " / " & total & ")"
        .LBL_Info.Caption = fileName & _
        .LBL_Bar.Width = percent * (.Frame1.Width - 10)
    End With
    DoEvents
End Sub
'  FOLDER PICKER – 64-bit safe
End Function
but I can still see parts being opened/closed
Any other idea?
Lucas
bgrittmann
CATIA V5R19
erstellt am: 09. Mrz. 2026 16:19    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Hi
Try .Read instead of .Open.
Regards,
MICHLICK
CAD Methodik Entwickler (CATIA; NX)
Sehen Sie sich das Profil von MICHLICK an!   Senden Sie eine Private Message an MICHLICK  Schreiben Sie einen Gästebucheintrag für MICHLICK
Der Aufwand bei Änderungen ist groß, wenn die Finger schneller klicken als das Gehirn denkt.
erstellt am: 16. Mrz. 2026 14:11    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Sounds for me that this should better run in batch mode.
Why batch? You just load and save a bunch of files and have no user interaction. No need to run this interactive (except for file path selection but this can be solved in a different way).
In batch mode you can't enter a folder path. You could set a parameter or define a file where you write the path of the folder. If CATIA starts in batch mode it is not visible and you can run this parallel to your interactive CATIA session.
Gruß Michael B.
