  ENOVIA SmarTeam
  ProE Integration launching error
Autor Thema:  ProE Integration launching error (743 mal gelesen)
j_d
Sehen Sie sich das Profil von j_d an!   Senden Sie eine Private Message an j_d  Schreiben Sie einen Gästebucheintrag für j_d
erstellt am: 05. Mai. 2005 15:26    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Dear List Members,
Sorry for writing in English.
I've following problem - generally speaking the ProE Integration doesn't work :-( After installation of ProE integration and Gateway while launching ProE I got the following error message:
"AGW server will not start, wrong Pro/Engineer version!
Required Pro/Engineer version Wildfire
Manufacturing code at least 2003051"
and then
"Startup of application "AGWSyncServer" failed."
My configuration:
- ST V5R14 SP1,
- MS SQL database (SmDemo),
- ProE Wildfire (manufacturing code 2004150)
I've installed the correct Gateway (for Wildfire, not 2001).
Here is the fragment of "Information window" from ProE:
License Information
Service Contract Number: 3A320469
Release: Wildfire 2.0
Pro/ENGINEER Date Code: M070
License Name: PROE_Educ1
License Version: 25.0
Auxiliary application Information
Application 0: AGWSyncServer
Exec path: C:\Program Files\RAND Worldwide\AGW 4.2 for ProEWildfire\AGWSyncServer.dll
Text path: C:\Program Files\RAND Worldwide\AGW 4.2 for ProEWildfire\SAGW
Version 25 - 2003170
Application is not running.
Regards,
Jack
