  ENOVIA SmarTeam
  smarteam installation with ibm db2
Autor Thema:  smarteam installation with ibm db2 (1420 mal gelesen)
smarteam
Hiwi
Sehen Sie sich das Profil von smarteam an!   Senden Sie eine Private Message an smarteam  Schreiben Sie einen Gästebucheintrag für smarteam
erstellt am: 17. Dez. 2003 17:45    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
hi
i am raj,i was assigned task of installing smarteam software,i even dont have basic knowledge about smarteam
,anyhow i studied some help online and started to install,i have installed smarteam foundation and also smarteam editor and installed ibm db2 on my system.
operating system : windows server  2003 enterprise edition
problem is : affter installing all those,i just started using it,i have clicked on database connection manager to configure smarteam with ibm db2,i have clicked on add conenction.
  it is asking for datasource name and username and password.
  i have found a system dsn that is created by default for the ibm db2 i.e, DWCTRLDB,i entered that name
    and clicked on test connection,it gave message that it is succesfull
then i clicked next :it is asking for username and password once again,but i am not able to know what is the  username and password that i should supply here.any how i supplied username as administrator and password of administrator of the system,but i get the error message like
could not connect to specified database.Please check your configuration( [DB2/NT] sql0104N "USERNAME.TDM_DB_VERSION" is not a defined name. SQLSTATE=42704)
tried to search in internet,but could not find one.
Also let me know,whether we should create a new database for the smarteam,or can we use the DWCTRLDB database for the
smarteam applications
      i am  very sorry if my question is unclear,please help me in this regard.if any information is needed please
let me know.
i am desperate for the answer,as i am trying it for past 15 days..
bye
raj
mkh
Sehen Sie sich das Profil von mkh an!   Senden Sie eine Private Message an mkh  Schreiben Sie einen Gästebucheintrag für mkh
Wer aufhört besser zu werden, hat aufgehört gut zu sein.
erstellt am: 19. Jan. 2004 14:23    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für smarteam 10 Unities + Antwort hilfreich
hy raj,
the error message you describe appears, if the database you try to connect is not a smarteam database. just create new smarteam database with the data model designer and try it again.
good luck
mkh
ChristianS
Leiter Kundenbetreuung
Sehen Sie sich das Profil von ChristianS an!   Senden Sie eine Private Message an ChristianS  Schreiben Sie einen Gästebucheintrag für ChristianS
erstellt am: 19. Jan. 2004 17:18    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für smarteam 10 Unities + Antwort hilfreich
Hi raj,
the first Connection Test and the answer 'successful connection' describe that you can connect to the server. It does not clearify that you have access to the DB's.
The Errormessage you describe is possible, like mkh explain, and also with a correct SMARTEAM database but missing Accessrights for the tables.
Regards,
Christian
smarteam
Hiwi
erstellt am: 20. Jan. 2004 12:09    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
hi
mkh and christianS ,first let me thank you for replying to my question.i have tried many times,but now i just stopped the  installation of smarteam for few days as now i am installing and configuring proe..so after completion of this task , i will try with ur solution and let u know if i got any errors.
thanks for ur reply
regards
raj
Goosnargh
Sehen Sie sich das Profil von Goosnargh an!   Senden Sie eine Private Message an Goosnargh  Schreiben Sie einen Gästebucheintrag für Goosnargh
erstellt am: 30. Mai. 2006 10:42    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für smarteam 10 Unities + Antwort hilfreich
Zweieinhalb Jahre später, gleiches Problem
Wenn ich mit rechts auf die Datenbank gehe und dann auf Berechtigungen sind dort alle Rechte gesetzt.
Gibt es für die "Tables" noch irgendwo anders Rechte die ich zuweisen muss? (ich weiss nichtmal was tables sind, hab erst seit gestern denn spass mich mit DB2 und Smarteam auseinanderzusetzen...)
Ich wär echt dankbar über jede Hilfe!
