  FEM allgemein
  ACP ANSYS Interlaminar stresses in shell elements and Temperature distribution
Autor Thema:  ACP ANSYS Interlaminar stresses in shell elements and Temperature distribution (729 mal gelesen)
AchilleasMil
Mechanical Engineering Student
Sehen Sie sich das Profil von AchilleasMil an!   Senden Sie eine Private Message an AchilleasMil  Schreiben Sie einen Gästebucheintrag für AchilleasMil
erstellt am: 24. Aug. 2018 20:20    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
I want to run a thermal analysis using ANSYS on a sandwich plate with honeycomb core and laminated facesheets, to see how the temperature distributes in every layer and what kind of interlaminar shear stresses it might produce between each layer of the laminated facesheets.
I have modelled the facesheets as shell elements.
Is there a possibility to see the temperature distribution in every layer using the ACP feature of Ansys while having shell elements?
Is there a possibility to do that maybe by having solid elements instead of shells? Untill now when I set the faces as solids and try to open the setup feature in the ACP Pre Tab I get the : Input validation error : there is no data contained in the input mesh file. Although I have alredy meshed my model.
And after that even in a basic static structural analysis of my model I cannot find how I can plot interlaminar stresses in the ACP-Post Tab? Are there any tutorials on interlaminar stresses? Which stresses excactly can ANSYS compute and how to plot them?
Because in the solution part in Mechanical of the Static Structural Tab I can only request a shear stress plot based on the planes, but I don't know if that is for interlaminar shear stresses or for each lamina.
Can you help me?
Gratefully,
Achilleas Milios
Mustaine
Sehen Sie sich das Profil von Mustaine an!   Senden Sie eine Private Message an Mustaine  Schreiben Sie einen Gästebucheintrag für Mustaine
Abaqus
erstellt am: 27. Aug. 2018 14:25    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für AchilleasMil 10 Unities + Antwort hilfreich
