Hallo!! Ich habe viele Probleme seit Wochen lang und ich hoffe jemand konnte mir helfen. Ich habe ein Kran die mit 2 Servomotoren eine Last hebt. Vielleicht es ist besser wenn ich es auf Englisch erkläre:
It´s like the cranes that lift sand from the ground, with different joints. And I want to know the forces and torques on this joins in different positions. For example, when the head that holds the sand it´s more extended, the force in the joint willbe greater than when it´s more horizontal. And I want to know this differences from forces and analize it. I tried it with "in struktur verwenden" but it just tells me the forces and torques from the servomotor in one position. And I´m not sure if this values correspond to the forces just from the motor, or to the complete forces of all system: The weight of the sand, gravity (which I already applied), and the forces from the structure.
Maybe I can take it to simulate and there I can proceed with the masses, with material.. But I tried it and I couldn´t found value of the forces.
Thanks a lot!
