hi ich offe ich bin da im richtigen bereich gelandet.
gleich zu meinem prob. ich lad mir die autocad 2012 studentenversion runter install. sie dann kommt diese fehlermeldung
2013/5/7:00:10:50 michael MICHAEL-PC === Setup started on MICHAEL-PC by michael ===
2013/5/7:00:10:50 michael MICHAEL-PC Launch
2013/5/7:00:11:15 michael MICHAEL-PC === Setup ended ===
2013/5/7:00:10:52 michael MICHAEL-PC === Setup started on MICHAEL-PC by michael ===
2013/5/7:00:10:52 michael MICHAEL-PC Launch
2013/5/7:00:11:17 michael MICHAEL-PC PageOpen LaunchDialog
2013/5/7:06:56:20 michael MICHAEL-PC PageOpen LicenseDialog
2013/5/7:07:12:34 michael MICHAEL-PC PageOpen ProductInfoDialog
2013/5/7:07:15:26 michael MICHAEL-PC PageOpen ProductSelectionDialog2
2013/5/7:07:15:48 michael MICHAEL-PC PageOpen FullProgressDialog
2013/5/7:07:15:48 michael MICHAEL-PC Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1031.exe /q
2013/5/7:07:15:58 michael MICHAEL-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=5100
2013/5/7:07:15:59 michael MICHAEL-PC PageOpen InstallCompleteDialog
2013/5/7:07:16:42 michael MICHAEL-PC === Setup ended ===
2013/5/7:16:50:12 michael MICHAEL-PC === Setup started on MICHAEL-PC by michael ===
2013/5/7:16:50:12 michael MICHAEL-PC Launch
2013/5/7:16:50:37 michael MICHAEL-PC === Setup ended ===
2013/5/7:16:50:13 michael MICHAEL-PC === Setup started on MICHAEL-PC by michael ===
2013/5/7:16:50:13 michael MICHAEL-PC Launch
2013/5/7:16:50:48 michael MICHAEL-PC PageOpen LaunchDialog
2013/5/7:16:52:03 michael MICHAEL-PC PageOpen LicenseDialog
2013/5/7:16:52:07 michael MICHAEL-PC PageOpen ProductInfoDialog
2013/5/7:16:52:53 michael MICHAEL-PC PageOpen ProductSelectionDialog2
2013/5/7:16:53:08 michael MICHAEL-PC PageOpen FullProgressDialog
2013/5/7:16:53:08 michael MICHAEL-PC Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1031.exe /q
2013/5/7:16:53:17 michael MICHAEL-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=5100
2013/5/7:16:53:18 michael MICHAEL-PC PageOpen InstallCompleteDialog
2013/5/7:16:55:11 michael MICHAEL-PC === Setup ended ===
2013/5/7:17:17:57 michael MICHAEL-PC === Setup started on MICHAEL-PC by michael ===
2013/5/7:17:17:57 michael MICHAEL-PC Launch
2013/5/7:17:18:09 michael MICHAEL-PC === Setup ended ===
2013/5/7:17:17:59 michael MICHAEL-PC === Setup started on MICHAEL-PC by michael ===
2013/5/7:17:17:59 michael MICHAEL-PC Launch
2013/5/7:17:18:09 michael MICHAEL-PC PageOpen LaunchDialog
2013/5/7:17:19:12 michael MICHAEL-PC PageOpen LicenseDialog
2013/5/7:17:19:17 michael MICHAEL-PC PageOpen ProductInfoDialog
2013/5/7:17:19:42 michael MICHAEL-PC PageOpen ProductSelectionDialog2
2013/5/7:17:19:45 michael MICHAEL-PC PageOpen FullProgressDialog
2013/5/7:17:19:46 michael MICHAEL-PC Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1031.exe /q
2013/5/7:17:20:44 michael MICHAEL-PC Install .NET Framework Runtime 4.0 Language Pack Succeeded
2013/5/7:17:20:44 michael MICHAEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/5/7:17:21:11 michael MICHAEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/5/7:17:21:11 michael MICHAEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/5/7:17:21:44 michael MICHAEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/5/7:17:21:44 michael MICHAEL-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/5/7:17:23:36 michael MICHAEL-PC Install DirectX Runtime Succeeded
2013/5/7:17:23:36 michael MICHAEL-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/7:17:24:19 michael MICHAEL-PC Install FaroSDK Succeeded
2013/5/7:17:24:19 michael MICHAEL-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/7:17:25:19 michael MICHAEL-PC Install Autodesk Material Library 2012 Succeeded
2013/5/7:17:25:19 michael MICHAEL-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/7:17:26:45 michael MICHAEL-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/5/7:17:26:45 michael MICHAEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\michael\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/5/7:17:27:47 michael MICHAEL-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/5/7:17:27:47 michael MICHAEL-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/7:17:28:43 michael MICHAEL-PC Install Autodesk Content Service Succeeded
2013/5/7:17:28:51 michael MICHAEL-PC Installing AutoCAD® Mechanical 2012: TRANSFORMS="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\x64\de-de\acadm\acad.mst;C:\Users\michael\AppData\Local\Temp\_AIA563.tmp\x64\acadm\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Mechanical 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/7:17:55:02 michael MICHAEL-PC Install AutoCAD® Mechanical 2012 Succeeded
2013/5/7:17:55:05 michael MICHAEL-PC Installing AutoCAD® Mechanical 2012 Language Pack: TRANSFORMS="C:\Users\michael\AppData\Local\Temp\_AIA563.tmp\_la988E.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Mechanical 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/7:18:09:46 michael MICHAEL-PC Install AutoCAD® Mechanical 2012 Language Pack Succeeded
2013/5/7:18:09:47 michael MICHAEL-PC Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\x64\de-de\InventorFusion\InventorFusion.mst;C:\Users\michael\AppData\Local\Temp\_AIA563.tmp\x64\InventorFusion\Inve ntorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Mechanical_2012_German_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/7:18:09:51 michael MICHAEL-PC Install Autodesk® Inventor® Fusion 2012 Failed Installation aborted, Result=1618
2013/5/7:18:09:54 michael MICHAEL-PC Rollback AutoCAD® Mechanical 2012 Language Pack Failed Installation aborted, Result=1618
2013/5/7:18:09:59 michael MICHAEL-PC Rollback AutoCAD® Mechanical 2012 Failed Installation aborted, Result=1618
2013/5/7:18:10:02 michael MICHAEL-PC Rollback Autodesk Content Service Failed Failure is ignored, Result=1618
2013/5/7:18:10:06 michael MICHAEL-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1618
2013/5/7:18:10:10 michael MICHAEL-PC Rollback Autodesk Material Library 2012 - Low Resolution Failed Installation aborted, Result=1618
2013/5/7:18:10:15 michael MICHAEL-PC Rollback Autodesk Material Library 2012 Failed Installation aborted, Result=1618
2013/5/7:18:10:19 michael MICHAEL-PC Rollback FaroSDK Failed Failure is ignored, Result=1618
2013/5/7:18:10:23 michael MICHAEL-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2013/5/7:18:10:27 michael MICHAEL-PC Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1618
habe das frame works mit einem cleaner deinstalliert und neu install. funktioniert leider nicht
freu mich schon auf antworten
PS:hab die suchfunktion und nat. auch gegoogelt aber bis jetzt nichts gefunden was das prob lösen konnte
mfg mipl
HALLO
