Hallo cad4fun,
also früher funktionierte das mal so wie hier beschrieben:
schnipp...
% Now the map of AutoCAD color numbers to output colors, using the
% CMYK (Cyan-Magenta-Yellow-blacK) model.
% Each line should have four numbers between the square brackets
% on that line. The first number should range from 1 (maximum amount of
% cyan) to 0 (no cyan); the second number should range from 1 (maximum
% amount of magenta) to 0 (no magenta); the third number should range
% from 1 (maximum amount of yellow) to 0 (no yellow); and the fourth
% number should range from 1 (maximum amount of black) to 0 (no black).
% For example, black is formed by [ 0 0 0 1], white is formed by
% [ 0 0 0 0 ], and cyan is formed by [ 1 0 0 0 ].
% The original entries in this array map each of the first fifteen colors
% to reasonable approximations of themselves (assuming AutoCAD is in 16
% color mode with no color customization).
% This array must have at least as many entries as LGP_colortowidth. If it
% has more entries than LGP_colortowidth, the extra entries are ignored.
% Colors that are not covered in this array are mapped to the RGB color
% specified for the last used entry in the array.
....schnapp
Da musste man dann nur die entsprechenden Farbnummern eintragen.
Aber wie schon gesagt, ich mache es heute auch lieber im Illustrator
Gruß Heidi
http://www.cad-point.de
