das könnte an der Art der Installation liegen. Hier die Infos der Autodesk:
Standard parts unavailable when logged in as domain user
Published date: 2002-09-30
Applies to:
AutoCAD® Mechanical 6
Autodesk® Mechanical Desktop® 6
Issue
You installed Autodesk® Mechanical Desktop®, including the standard parts, as a local administrator on your machine. However when you are logged in as a domain user you cannot insert any standard parts.
Solution
This problem can be caused by insufficient permissions of the domain user. The user needs to be granted edit permissions for the Autodesk Mechanical Desktop folder, by either changing the security settings for the Autodesk Mechanical Desktop folder or adding the domain user to the local power user group or local administrator group.
Felix www.cad-ausbildung.de------------------
Felix
Klinkenbergh
