Nachtrag für jemanden, der die gleiche Frage hat:
In dem
Strang von Mechman hat
invhp ein paar Netzverweise und Tipps für eine saubere Deinstallation gegeben. Der Vollständigkeit halber, füge ich diese in meinen Beitrag hinzu.
Deinstallation Inventor 2008 (Prof/Suite):
1. Log on as Local System Administrator and disable any virus-scanning programs.
2. In the Control Panel (Windows), double-click Add or Remove Programs.
3. In Add or Remove Programs, remove the following program:
*Autodesk Inventor 2008 (Suite, Professional, Routed Systems, or Simulation)
4. Using Windows Explorer, browse to and delete the following directories:
* On 32-bit operating systems:
o C:\Program Files\ Autodesk\Inventor 2008
o C:\Documents and Settings\All Users\Application Data\Autodesk\Autodesk Inventor 2008
* On 64-bit operating systems:
o C:\Program Files (x86)\ Autodesk\Inventor 2008
5. Click Start menu (Windows) > Run.
6. In the Run dialog box, enter regedit in the Open box and click OK to open the Registry Editor.
Warning! Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft provides a wealth of critical information that you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined for your operating system in the Microsoft Knowledge Base and in the related solution, TS66513. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
7. In the Registry Editor, locate the following subkeys and delete them:
o HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor\RegistryVersion12.0
o HKEY_CURRENT_USER\Software\Autodesk\ Inventor\RegistryVersion12.0
o HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Autodesk\Inventor\RegistryVersion12.0
8. Exit the Registry Editor.
9. Restart the computer.
10. Log on as Administrator and disable any virus-scanning programs.
11. Reinstall Autodesk Inventor.
Note: If you have Autodesk® Vault Explorer installed, you need to perform a repair of it in Add or Remove Programs (Windows) in order to fix the Inventor integration.
Quelle
Wenn der Wind weht, löscht er die Kerze aus und facht das Feuer an.
