gemacht.
Damit fallt die ewige klickerei flach.
Zur Vorbereitung kopiere Ich die benötigten Hotfixes & ServicePacks in ein Verzeichnis.
Die ServicePacks die als .EXE ausgeliefert werden habe ich vorher extrahiert, z.B.:
ADMS2008_Sp1.exe /e ADMS2008_Sp1.msp
@echo off
clsecho --------------------------------------------------------------------------------
echo - Autodesk Inventor Professional 2008 SP2 (build #320)
TS1079646_AI2008_SP2.msp /passive
echo - ADMS SP1 Hotfix
echo - The vault pane in Inventor may intermittently display a '?' instead of the
echo correct vault status in Inventor
rem TS1078426.msp /passive (dringend README lesen, sonst gibt es Datenbankfehler)
echo - Filename and path property in a title block causes prompting to save when
echo closing an IDW
echo - Crashing when using Custom View to create a drawing view when the Customer
echo Involvement Program option is set to on
TS1078886_AI2008_SP2.msp /passive
echo - Editing iPart leads to inconsistent update in the iAssembly
TS1078966_AI2008_SP2.msp /passive
echo - Renaming an iFeature corrupts table and member scope editing
TS1079146_AI2008_SP2.msp /passive
echo - Using Refresh checks out files which will not be modified
TS1078646_AI2008_SP2.msp /passive
echo - When performing a copy design the link to a third party file is not updated.
TS1079606_Vault_SP1.msp /passive
echo - An inventor assembly file whose redirection stream has been updated to point
echo to new ole link, is still unable to resolve the link properly.
rem TS1079127_AI2008_SP2.msp /passive (CRASH beim übernehmen von Projekt in Vault)
echo - Assembly features grow the assembly file size dramatically
echo - Opening a file generates a warning "Serious error message
echo "String resource could not be loaded ...".
echo - Drawing prompts for save on close of an unchanged idw file due to the
echo OLE present in the title-block.
echo - Application crash when memory saving mode is on.
echo - After installing Inventor 2008 SP2 , Inventor 2008 will crash on open of an
echo assembly (Vista only).
TS1081186_AI2008_SP2.msp /passive
echo - crash when sketch is edited or a part is rotated
echo - resolves display glitches after an assembly is rotated with
echo ATI FireGL V3300 card and Vista Business Operating System
TS1081366_AI2008_SP2.msp /passive
echo - Derived parts not updating
TS1080986_AI2008_SP2.msp /passive
echo .
pause
