| PDM Ablösung von Productstream Professional auf GAIN Collaboration (GAIN Collaboration,PDM,PDM System,PLM,PLM System) |
Thema: Servicepack2 (3692 mal gelesen)
thomas109 Moderator Dompteur
erstellt am: 25. Jan. 2003 02:06 <-- editieren / zitieren --> Unities abgeben:
Jetzt gibts SP2. 13,2MB. ISSUES ADDRESSED BY THIS UPDATE ================================= Summaries of the issues addressed in Autodesk Inventor 6 Service Pack 2 include: 1. Assembly Modeling: (assemblies, presentations, adpativity, welds) An Adaptive Workflow does not work restructure is crashing when throwing from a sub to the top level target Edting Constraint crashes inventor (depending on how you do it) Edit part sketch in context corrupts part. Crash projecting extrude cut edge to sheet metal sketch. FEATURES CREATED IN PART AFTER SUPPRESSING ASSM FEAT TURN INVISIBLE ADAPTIVE PART CAUSES ASSEMBLY TO CRASH WHEN UPDATING ALL Drive constraint dialog refuses to stay minimized while recording avi Quick exit trying to open customer 5.3 assembly. Assembly mate constraint becomes sick after migrating to R6 Assembly insert constraint becomes sick after migrating to R6 TTL assy migration creates sick insert constraint crash attempt to create reference sketch to patterned colleagu component Weld does not compute properly when assm feature cutting through it is suppressed. Crash selecting 'Sybol visibility' in Weldments Weldsym doesn't follow cosmetic weld when comp moves Crash clicking on Hide Trail when selecting a component in a non-active IPN view 2. API: Problem regarding owning ComponentDefinition of a SurfaceBodyProxy when it is obtained using FaceProxy.Parent Point type iFeature input does not accept non-workpoint selection Clean up of multiply functions of Matrix object. ExecuteSave fails after attribute access in Apprentice Param argument of GetParamAtLength method returns incorrect direction Cannot set End Of Part on Sheet Metal Features Loft creation ignores mapping points set by API 3. Data Exchange: (Iges, Step, SAT, Dwgin, Viz, Max, Dwgout & MDT translation) Inventor MAX plugin is only giving the first character of the inventor part imported as it's name DXFOUT: Cannot save sheet metal flat as DXF. DWGIN: importing into drawing sketch kills all existing drawing dimensions DWGIN: the text and geomety are detached for the imported sketched symbol. DWGIN: TO R6 (IDW) CONVERTS DIMENSIONS TO REFERENCE DIMENSIONS DWGOUT: perspective view is not exported correctly DWGOUT German (DIN) regional setting use commas and not decimal separator 4. Drawings: (Views, annotations, dims, sketches, standards) Crash updating view with recovered caterpillar Can't dim to a centerline extends to or beyond edge of a broken view Weld caterpillars do not display correct on intermittent welds. ACL - Encount error when apply auto centerline on axial hole in section view Crash recovering weld annotations HOLE TABLE: A hole once deleted from the table cannot be added back. Part stays in Partslist after it being referenced in model Custom (sketched) balloons cause Inventor to crash migration: balloon is sick upon opening in 6099SP1 Drawing corruption that results from using get work features CENTERLINE: 'Fit Center Mark' command makes center mark too small CENTERLINE: 'Extension Lines' command does not display the extension lines for a center mark Ordinate dims between views result in unstable behavior Using dimension opposite angle option doesn't update dimension value Unchecking dim option use quadrant causes dim to report wrong value Addmember dimension option behave weird Angular dimensions get sick Tolerance values gets invalidated Extension line not attached with symbols created on broken views crash print preview "sheets in range 1-2" Crash at creating draft view copy/paste sheet between docs then delete sheet Error Opening IDW file Annotations go sick when moving broken section view to new sheet Save this 6.0 idw in Sp1 or Sp2 and can't open new idw. Crash while applying tolerance to hole note R5.3 drawing- crash on open Center Mark and Center Line go sick on a view Sketch dimension becomes visible after migrating broken view Annotations attached to threads move on migration and update Annotations get sick upon migration to R6SP1 Crash when save and restore a drawing with a hole table Attempting to open the idw file after the migration, Inventor crashes. Views disappear after migrating drawing and switching sheets Crash opening attached R6 drawing file or attached pre-R6 file saved in R6 Balloons are sick after migrating broken detail view Crash attempting a copy/paste of a sheet into a new drawing User defined drawing borders also appear in the selection list of sketched symbols CRASHES ATTEMPTING TO CREATE A SECTION Planer edge from derived part not showing in drawing views Shaded cut vws bad then crash when drawing is deferred Creating iso view from view that has a broken view causes only half the view to show up in iso crash creating the section vw from the center Views recompute upon moving the parent view Color placed on faces of part do not show in presentation view, ipn View label does not retain its color upon view update No cross hatch on break out view on detail view. Break out on detail view does not show where sketch is Crash when creating a section view on this part Crash with "Get work features" on view Upon view creation a break out view's profile sketch is out of date with view base view on non active sheet does not get updated upon activating the sheet Breaking out a view to this edge of causes depth to be lost on view update Turning section off on assembly components removes the component from aligned section views. Crash while using "Get Work Features" after "Show contents" on a view of a part. Section view facets incorrectly at large scale Break lines not visible on shaded broken view 5. Design Assistant: Disallow any actions while Pack and Go is in search mode Pack and Go does not include subfolders in search for referencing files Crash canceling a pack n go dialog Folders starting with "." are skipped during Pack & Go Crash in Find when searching for empty custom property name No longer automatically do the search for referencing files when Pack and Go dialog is opened--user now has to push Search Now button to get the Referencing Files list. Fixed "Keep Folder Hierarchy" option, including, creating "Workgroups" and "NotInProject" subfolders in the destination folder . Fixed project files created by Pack and Go. Copy original project file to destination folder, under name <project-name>.ipj.old 6. Migration: Mig Util can't save mig files in batch DIR mode but can save indiv file select migration 7. Part Modeling: (features, sheet metal, graphics). assy rebuild fails first time, then succeeds without doing anything Part dispear when select a sketch in browser Wrong dimensions in idw after changing the tolerence option in ipt Chamfer regression from r53 to r6 ***** in coil from cut Deriving this part causes a crash in Emboss features created with adaptive bit set. From To Extrude on this part causes a bad body Rebuild feature fails just created feature after rebuild OK Draft causes failure of circular pattern Bad body after applying fillets to this loft Metric IPT/IDW but Tap Drill diameter in hole note is displayed in imperial units Crash editing IFeatures that are extracted with patterns or 3D sketches Crash applyin/converting IDE that's extracted with Distance Chamfer No RTTI data error Crashes while opening attached file Work points fail to update on Thicken vertices after upstream feature is edited Fold in attached R5.3 fails in R6 Same edge can be selected for sections Ground work point not able to snap to hole center Bad result converting an offset of a smooth fit spline to be a spline Cannot trim to a sketch pattern. 8. Content Library: ANSI.49 and ANSI.50 - many sizes fail due to bad SPD value Crash when Search finds many results 9. Plotting: shaded broken views dont print correctly -- shading exceeds cut line 10. Graphics: Wildcat default freezes workstation. ATI: Reg String substitution is incorrect Laptops with ATI Radeon card crashes on first launch when window is maximized and then clickin in graphics area 11. Other: (migration utility, install issues, Projects) OLE link broken, freezes Inventor Closing Inventor when this assembly is loaded crashes Extrusion of open profile fails on localized products Resolve checkout to wrong folder when project paths not in alpabetical order need all transcripts to supply file versions being open Regression: no longer message on open when project folders are missing Unable to open R7 parts in R6_SP1 R6 files should not have "yes" for Needs Migrating in R7 File-Save errors out after patterning IDE and finally crashes up on editing IDE ================================================================================== Notes: ====== Autodesk Inventor 6, Autodesk Inventor 6 Service Pack 1, and Autodesk Inventor 6 Service Pack 2 use the same file formats (.iam, .ipt, .idw, .ipn, .idv, .ide). All file types can be interchanged between these versions. The size of Autodesk Inventor 6 Service Pack 2 is approximately 15 MB. You must have a minimum of 40 MB of free disk space on the drive where your temporary files are directed for the update to complete successfully.
------------------ lg Tom mcds Datensystem GmbH Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Chefe Mitglied Geschäftsführer
Beiträge: 175 Registriert: 23.12.2002
erstellt am: 25. Jan. 2003 03:42 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 25. Jan. 2003 08:10 <-- editieren / zitieren --> Unities abgeben:
LK36 Ehrenmitglied MB-Techniker / Konstruktion
Beiträge: 1794 Registriert: 14.03.2002 i9-9900KF 8x3.6/5Ghz / 64GB-RAM / Gef.-RTX3060-12GB / SpaceNavigator / Win10-64Pro / Inv.2021 Pro
erstellt am: 25. Jan. 2003 08:43 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Interessant, was ich heute für eine E-Mail erhielt : Von: EMEAsubscriptions@autodesk.com [mailto:EMEAsubscriptions@autodesk.com] Gesendet: Freitag, 24. Januar 2003 19:25 An: Betreff: Autodesk Inventor 6 Service Pack 1 jetzt verfügbar Autodesk Inventor 6 Service Pack 1 jetzt verfügbar Sie erhalten diese Benachrichtigung als Vertragserfüllungskoordinator für Ihre Autodesk Inventor Series-Lizenz(en), für die eine Subskription besteht. Autodesk versendet gegenwärtig an alle Subskriptions-Teilnehmer weltweit ein Upgrade zu Autodesk Inventor Series 6. Die Versandaktion ist nahezu abgeschlossen, so daß Sie Ihr Upgrade möglicherweise bereits erhalten haben.
Autodesk möchte Ihnen mitteilen, daß wir im Rahmen unserer fortlaufenden Bestrebungen, Ihnen Produkte anzubieten, die maximalen Qualitätsansprüchen gerecht werden, das Autodesk Inventor 6 Service Pack 1 veröffentlicht haben. Die README-Dateien, in denen alle Änderungen im einzelnen aufgeführt sind, sowie das Service Pack können unter folgender Adresse geladen werden: http://support.autodesk.com/deu/homepage.asp, "Herunterladen von Updates und Dienstprogrammen". Das aktualisierte Autodesk® VIZ- und 3ds max(tm)-Plug-In für Autodesk Inventor®-Dateien ist ebenfalls verfügbar. Mit Hilfe dieses Plug-Ins können Sie in Autodesk Inventor® erstellte Bauteil-, Baugruppen- und Präsentationsdateien (IPT, IAM, IPN) importieren. Wenn Sie das Service Pack 1 für Autodesk Inventor 6 installieren, müssen Sie zusätzlich dieses Update laden und installieren, um Inventor-Dateien in Autodesk VIZ und 3ds max importieren zu können. Treffen Sie auf der Download-Seite folgende Auswahl: Produkt: Autodesk Inventor Version: 6 Kategorie: Updates und Wartungsversionen Bitte geben Sie diese Mitteilung, soweit erforderlich, in Ihrem Unternehmen weiter. Sollten Sie weitere Unterstützung im Umgang mit Service Pack 1 benötigen, wenden Sie sich bitte an Ihren Autodesk Inventor Series-Fachhändler. Vielen Dank! Autodesk Worldwide Subscription Team
------------------ Lutz Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Sven_W Mitglied Konstrukteur
Beiträge: 352 Registriert: 25.09.2001 WINDOWS 10;IV2019;MTD2019; VaultPro2019 Raum GRZ(Greiz); Jeder ist sich selbst der Nächste, da ist der Weg auch nicht so weit.(Fix und Foxi-Heft) "Gilde der Erfinnder"
erstellt am: 25. Jan. 2003 09:50 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
TB Sattler Mitglied Staatl. gepr. Techniker f. Maschinenbau
Beiträge: 1065 Registriert: 14.11.2001 Hard- und Software aktuell
erstellt am: 25. Jan. 2003 11:00 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Charly Setter Moderator
erstellt am: 25. Jan. 2003 14:06 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 25. Jan. 2003 14:26 <-- editieren / zitieren --> Unities abgeben:
NobbiB Mitglied
Beiträge: 579 Registriert: 05.12.2001 MS Windows XP Pro SP2 P4 3,4 GHz, 2GB RAM, Nvidia Quadro4 XGL900
erstellt am: 25. Jan. 2003 15:33 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
"Unable to open R7 parts in R6_SP1" "R6 files should not have "yes" for Needs Migrating in R7" Was soll uns das nun wieder sagen??? Meine Güte...denn sie wissen nicht was sie tun! Schönes Wochenende! NobbiB Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Lucian Vaida Moderator Dipl.-Ing. / Konstruktion
Beiträge: 3823 Registriert: 14.11.2002 Inventor 2024.2 Windows 11 Pro 23H2 DELL 7760
erstellt am: 25. Jan. 2003 16:10 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Oder IV7 befindet sich bereits im Beta-Test und die Firmen, welche darin involviert sind haben Probleme im Schnittstellenbereich. So abwegig dürfte dieses Variante gar nicht sein. Und wenn’s nicht so sein sollte, wissen wir zumindest wie Gerüchte in die Welt gesetzt werden. Gru0, Lucian
erstellt am: 25. Jan. 2003 16:18 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 25. Jan. 2003 16:46 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Hi Tom! Ich vermute, dass er einfach nur den Begleittext für SP2 gelesen hat. Also können wir feststellen, dass alle (na ja, oder fast alle) wundersam anmutenden Dinge auch eine triviale Erklärung haben. Die Macht sei mit dir! und schöne Grüße, Lucian Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
vnull Mitglied Maschinenbaumechanikermeister Konstruktion Sondermaschinenbau
Beiträge: 90 Registriert: 07.08.2002 Inventor 2010,Inventor 2011 DELL Precision 390 2x EiZO S2410W Vault Workgroup
erstellt am: 25. Jan. 2003 17:10 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 25. Jan. 2003 18:06 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Hallo Sven, Die Mittellinien im Zusammenbau sind ein Feature, das niemals in einem SP dazugenommen wird, sondern nur in einem Release. (irgend so ein Gesetz in USA). Ich habe deutliche Zeichen dafür bemerkt, daß das in R7 dabeisein wird (mit Option ein/aus). Zur DWG-Exportmisere gibt's neben den sehr guten Info's hier einen aktuellen Artikel in der knowledge base. Was im SP überhaupt drinnen ist? Hmmm...Ist mir nach Stunden herumspielen immer noch nicht abgestürzt! Wahrscheinlich ist was nicht drinnen - Bugs nähmlich! mfg _ Leo Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 25. Jan. 2003 19:10 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 25. Jan. 2003 19:18 <-- editieren / zitieren --> Unities abgeben:
Hi Sven! Überlesen? Im Frühjahr gibts alles neu. AutoCAD 2004, Mechanical 7, MDT7, Inventor 7. Genaues Datum: selber im Kaffeesatz lesen. Mein Gefühl: Mai. @Leo: poste doch hier bitte den Link zum Artikel der Wissensdatenbank (DWG-Export). Daß da die S...... am dampfen ist, habe ich in der letzten Stunde gesehen. Ich wollte heute den Erfinder nicht vor Sonnenuntergang anrühren, und jetzt hat er mir das Wochenende versaut.
erstellt am: 25. Jan. 2003 21:31 <-- editieren / zitieren --> Unities abgeben:
- Probiert mal einen ein Schnitt durch eine BG, anschließend bei den Normteilen den Schnitt abschalten und dann die Schraffur begutachten. Bei mir schauts interessant aus. Zusatz: Ist inzwischen beim AD-Support - Bohrungs- und Gewindeinfo im Schnitt abrufen (probieren ...). - Bei einem Halbschnitt durch eine Welle die dünnen Linien in der Projektion der Schnittumlenkung unsichtbar schalten (meine Anzeige dreht dann fallweise durch, wie ich es zu 5.0-Zeiten bei Kunden gesehen habe). - Im Schnitt den Abstand einer Bohrung zur Mittelachse bemassen versuchen ... Wer noch mehr interessante Neuigkeiten findet, ich sammle eine Liste für Montag! ------------------ lg Tom mcds Datensystem GmbH [Diese Nachricht wurde von thomas109 am 25. Januar 2003 editiert.] [Diese Nachricht wurde von thomas109 am 31. Januar 2003 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Robby Lampe Mitglied
Beiträge: 1026 Registriert: 18.10.2000
erstellt am: 25. Jan. 2003 21:46 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 25. Jan. 2003 22:31 <-- editieren / zitieren --> Unities abgeben:
Hi Robby! So wie ich das lese, bezieht sich das alles ganz klar nur aufs Installationsprogramm. Somit ist alles wieder in Ordnung! ********************************************************** ******************************* ***************************************** **************************** ------------------ lg Tom mcds Datensystem GmbH [Diese Nachricht wurde von thomas109 am 26. Januar 2003 editiert.] [Diese Nachricht wurde von thomas109 am 31. Januar 2003 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 26. Jan. 2003 11:26 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Hallo Thomas, Den link zum Artikel Knowledgebase gibt's später, wenn alle das SP runtergeladen haben und Autodesk.com wieder normal zugänglich ist, aber es ist ganz einfach: Produkt: Inventor, Release: 6, alle Kategorien....der 3. oder 4. Artikel nach Aktualität sortiert (gleich nach dem neuen Viz-plugin). Zu Deinen Problemen: - Schnitt durch BG, Normteile nicht geschnitten...Schraffur schaut ganz gut aus (abgesehen von den blöden Schraffurwinkeln) - Bohrungsinfo funktioniert ebenso - Halbschnitte mache ich nie (hat mir mein HTL-Lehrer vor 25 Jahren schon verboten <g> ) - Weiteres habe ich noch nicht probiert... mfg - Leo (schönen Ski-Sonntag?)
erstellt am: 26. Jan. 2003 21:09 <-- editieren / zitieren --> Unities abgeben:
Hi Leo! Den Link schau ich mir morgen früh an. Meine Probebaugruppe schaut heute abend genau so falsch aus wie gestern. Aber morgen habe ich ein paar verschiedene Kisten zum Gegenchecken. Der erste DWG-Export hat auch keine Verbesserungen gezeigt. Lichtblicke: - Pack&Go schaut jetzt vernünftiger aus - Siegis Problem mit dem Plunger dürfte jetzt gelöst sein (Nein, ist es nicht, schaut nur anders aus) ------------------ lg Tom mcds Datensystem GmbH [Diese Nachricht wurde von thomas109 am 31. Januar 2003 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Meex Mitglied Technischer Zeichner
Beiträge: 404 Registriert: 27.08.2002 Inventor 7 - SP1/2 Windows 2000 AMD 1900 GeForce4 Ti4400 1 GB Ram
erstellt am: 27. Jan. 2003 08:53 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
hi zusammen !! mich wundert es immer wieder wie autodesk es schafft keinen vernünftigen .dwg export zustande zu bekommen!!! vieleicht sollten einmal mitarbeiter von autodesk in diesen forum einige beiträge lesen !!!! sehe leider beim .dwg export keine besserung durch SP2 ------------------ Schöne Grüße Meex --------------------------- Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
mtl3d Ehrenmitglied Konstrukteur
Beiträge: 1544 Registriert: 03.05.2002 Pro/E Wildfire, Mechanica, Acad, Inventor, 3DS-MAX, NT, W2K, XP, Linux
erstellt am: 27. Jan. 2003 08:59 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Malo Mitglied Konstrukteur+NC-Programmierer+Arbeitsplaner
Beiträge: 921 Registriert: 09.04.2001
erstellt am: 27. Jan. 2003 09:21 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Hallo Meex, die kennen kein dwg mehr sondern nur noch idw. Kann mir jemand sagen warum ich die Mittellinien im M6 erst in den Ursprung zerlegen muss damit ich eine Linie bekomme? Bleibt nur noch zu hoffen das der Bernhard an seinem Tool "idwtodwg" weitermacht. Gruss Bernd
erstellt am: 27. Jan. 2003 09:45 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
hi leute ! habe von einer .idw einen .dwg export gemacht (IV6 mit sp2). habe die .dwg mit mechanical desktop 6 geöffnet. doch beim schließen habe ich eine interessante fehlermeldung bekommen :-)))) ANHANG: war dewegen weil ein befehl noch aktiv war ------------------ Schöne Grüße Meex --------------------------- [Diese Nachricht wurde von Meex am 27. Januar 2003 editiert.] [Diese Nachricht wurde von Meex am 27. Januar 2003 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
mechanical Mitglied Entwicklungsingenieur
Beiträge: 192 Registriert: 28.06.2002
erstellt am: 27. Jan. 2003 11:40 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Hallo Leute Offensichtlich hat ADesk eine neue "Norm" für Mittelpunktmarkierungen erfunden (Bild). @Leo Keine Bugs? Mit 3 Abstürzen innerhalb 10min kann ich das nicht bestätigen. ------------------ mechanical [Diese Nachricht wurde von mechanical am 27. Januar 2003 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Beiträge: 175 Registriert: 23.12.2002 Eplan electric P8 professional Build 1.8.5.2413
erstellt am: 27. Jan. 2003 12:10 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Schnitt durch die Baugruppe, Normteile nicht geschnitten tut zwar jetzt, aber nur wenn's eine normale Schnittansicht ist. Probiert das mal in der Ausbruchansicht, also bei mir tut's nicht auch wenn bei den Normteilen in allen Ansichten der Schnitt deaktiviert ist. Gruß Oliver ------------------ HKE GmbH Automatisierungstechnik Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
legenb Mitglied Techniker
Beiträge: 859 Registriert: 19.03.2002 Produktion IV 2011 Win7 Pro 64 Bit HP 8770w
erstellt am: 27. Jan. 2003 13:10 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Hallo Leute, gut das ich hier rein geschaut habe. Als ich die Mail mit dem SP1 bekommen habe, wollte ich sie schon ignorieren. Ich konnte mich bislang noch nicht durch ringen den IV6 aufzuspielen. Wir arbeiten mit 8 Plätzen immer noch mit dem IV5 SP2. Vielleicht kann mir jemand ein paar gute Gründe nennen, die Arbeit der Installation und die leidige Autorisierung auf mich zu nehmen. Einen schönen Tag noch Gruß Bernd Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
wirkau Mitglied Konstrukteur
Beiträge: 985 Registriert: 11.03.2002
erstellt am: 27. Jan. 2003 13:25 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
@Bernd (legenb) Mach's einfach. Eine Gruppe in unserem Laden arbeitet schon auf 6.0. Die "meinige" noch immer auf 5.3. Allein dei Möglichkeit innerhalb der Gruppe mit Reservierungen zu arbeiten ist ohne EDM "DER" Grund umzusteiegen. Un schlechter ist nichts geworden (Ausnahme "Schrauben mit Loch = Schraube mit Innensechskant, ich lach heut' noch darüber) ------------------ Gruß Peter --Alt darf ich werden, nur nicht vernünftig!-- Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Beiträge: 192 Registriert: 28.06.2002 ANSYS Workbench 15 @Windows 7 Workstation HP Z820 SolidWorks 2014
erstellt am: 27. Jan. 2003 13:57 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 27. Jan. 2003 14:03 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
daywa1k3r Ehrenmitglied V.I.P. h.c. Softwareentwickler
Beiträge: 3497 Registriert: 01.08.2002 Desktop: 3.3GHz;8GB;SSD OCZ Vertex 3;Gainward Phantom GTX570 Laptop: Alienware m17x Win7, Inventor2012 64Bi
erstellt am: 27. Jan. 2003 14:04 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 27. Jan. 2003 14:05 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 27. Jan. 2003 14:25 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Ja das ist eine Ableitung. Nach schließen und wieder öffnen war wieder alles ganz normal. Soviel zu den Bugs in SP2. Weiß schon jemand wie man die Mittelpunktmarkierungen wieder "normal" hinbekommt? Bei Radien macht der IV nun immer nur eine oder zwei Linien vom Mittelpunkt ausgehend. Bei Durchmessern passt es. Kann man das SP2 wieder entfernen? Es schaut so aus als ob es diesmal ein totaler reinfall war. ------------------ mechanical Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 27. Jan. 2003 14:39 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Ich weiß gar nicht was Ihr wollt. Ich kann mich dunkel an die Zeiten mit Tuschestiften erinnern, da sahen meine Zeichnungsköpe ähnlich aus. Nur leider gabs dabei kein schließem und wieder öffnen. Also Kopf hoch, alles wird besser Gruß Oliver ------------------ HKE GmbH Automatisierungstechnik Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 27. Jan. 2003 15:18 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Hallo! Auf den ersten Blick, scheint IV6 mit SP2 recht stabil zu sein. Zeichnungen, die uns unter SP1 am laufenden Band flöten gingen lassen sich jetzt absturzfrei bearbeiten. Mal schauen ob wir diese Erkenntnis auch in 2 Wochen bestätigen können. Gruß, Lucian Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 27. Jan. 2003 16:24 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 27. Jan. 2003 16:43 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Uwe.Seiler Mitglied Dipl.-Ing.(FH)
Beiträge: 1183 Registriert: 18.04.2002 HP xw6000 - Dual XEON 2,4GHz - 2GB DDRAM - 980 XGL (Treiber 84.26) - XP SP1 - IV11 SP3
erstellt am: 29. Jan. 2003 20:05 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 29. Jan. 2003 20:33 <-- editieren / zitieren --> Unities abgeben:
Hi Uwe! Nach einer knappen Woche: + stabiler + einige Sachen funzen besser (siehe readme, isso!) - DWG Export wie gehabt (seit Montag Funkstille von AD und Support) - kegelig gerollte Teile mit Ausklinkung gehen nach wie vor nicht (4 ja,5.0 ja, Sp1 ja, Sp2 nein, 5.3 alle SP ja bis 6, 6 mit SP1 nein , dzt. immer noch nein) IMHO: installieren und auf IV7 warten.
erstellt am: 29. Jan. 2003 22:17 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 29. Jan. 2003 22:50 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 30. Jan. 2003 08:44 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
"- DWG Export wie gehabt (seit Montag Funkstille von AD und Support) - kegelig gerollte Teile mit Ausklinkung gehen nach wie vor nicht (4 ja,5.0 ja, Sp1 ja, Sp2 nein, 5.3 alle SP ja bis 6, 6 mit SP1 nein , dzt. immer noch nein) IMHO : installieren und auf IV7 warten." Hallo Tom, d.H. bis IV7 (Mai,Juni,Juli) ist keine Besserung mit DWG Export in Sicht? @achim, bei mir funzt es mit den Fenstern! Gruss Bernd Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
MPeisler Mitglied
Beiträge: 95 Registriert: 31.01.2001
erstellt am: 30. Jan. 2003 09:42 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
Hallo Zusammen, da ich mit der stabilität vom Inv. keine Probleme habe werde ich wohl auf den Inv. 7 warten! Ich habe schon beim SP1 keine Veränderungen bemerkt. Vielleicht sind meine Teile aber auch nicht spektakulär genug Martin Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 30. Jan. 2003 09:46 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 31. Jan. 2003 18:59 <-- editieren / zitieren --> Unities abgeben:
@Alle! Letzter Abgabetermin für Fehlermeldungen und Bug-Reports ist Mittwoch. Übernächste Woche trommelt AD weltweit seine Leute zusammen. Ich kann unserer Vertretung (Ö) sachdienliche Hinweise auf nicht gefixte Fehler/neue Fehler durch SP2 mitgeben. Lamentieren und NiceToHave ist nicht drin, aber sachlich fundierte Probleme, am Besten mit kurzem Beispiel haben ein gute Chance an entscheidender Stelle zur Kenntnis genommen zu werden. Und die Wishlist für IV7 wird langsam Zeit. im April ist es sicher zu spät. Vielleich stellt unser Moderator sowas an die erste Stelle im Forum und mistet die dann auch gelegentlich aus (mal schauen, ob das Aktivitäten verteilen funktioniert ). Also Wochenende nutzen und die Probleme auf den Punkt bringen. Wir haben ein Chance, gehört zu werden. Wenn wir nur jammern und streiten bringst nichts. Ich hab einen eigenen Beitrag zu dem Thema aufgemacht. ------------------ lg Tom mcds Datensystem GmbH
erstellt am: 31. Jan. 2003 19:42 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
erstellt am: 03. Feb. 2003 20:34 <-- editieren / zitieren --> Unities abgeben:
"An der Verbesserung des DWG-Export wird gearbeitet. Die Probleme in der lokalisierten Version sind den Entwicklern mitgeteilt worden. Über den Zeitpunkt, wann die Verbesserungen für die Endkunden verfügbar sind, kann keine Aussage getroffen werden". ------------------ lg Tom [Diese Nachricht wurde von thomas109 am 03. Februar 2003 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 04. Feb. 2003 07:48 <-- editieren / zitieren --> Unities abgeben: Nur für thomas109
