Freitag Nachmittag und mal etwas Zeit die MCAD-Wellen abzureiten
Quelle: www.mymcad.com
Q: Hidden Commands (1006)
A: Each release of inventor has some hidden *UNSUPPORTED* and possibly dangerous commands contained within. Many of these commands are for debugging but occasionally you will find a gem!
To activate these command requires registry edits
Eg. Set the following registry key to a value of 1 in R4
NOTE: If you dont know how to edit a registry, you shouldn't be playing around in there. It can be very dangerous.
HKEY_CURRENT_USER|Software|Autodesk|Inventor|RegistryVersionX.X|System|Preferences|Show Test Toolbars
For different file modes, IPT, IAM, IPN, IDW, Sheet Metal etc, you will have new toolbars available. Investigate by RMB on a open grey menu area. For example in R4, in an assembly file, there is a toolbar named "Assembly Test" which contains a beautiful command called "Explode Assembly" (picture of a bomb). This command dynamically explodes assemblies like a zoom function. Remember this stuff is UNSUPPORTED!
Ein schönes WE
Foo
