Siehe:
http://support.autodesk.com/deu/Homepage.asp Set up the Autodesk Inventor™ plug-in for 3ds max™ 4 software
Applies to: Autodesk Inventor™ 5
Published Date:11/22/2001
Issue
You want to configure 3ds max™ 4 software to import Autodesk Inventor™ part, assembly, and presentation files.
Solution
To configure the Autodesk Inventor plug-in for 3dsmax 4:
Start 3ds max 4 software.
On the Customize menu, click Configure Paths.
In the Configure Paths dialog box, click the Plug Ins tab.
Click Add.
Navigate to the <inst dir>\bin directory, where <inst dir> is the default installation folder for Autodesk Inventor software.
Change the Label from "New Entry" to "Autodesk Inventor."
Click Use Paths and then click OK.
Exit 3dsmax 4.
Restart 3dsmax 4.
You can now import Autodesk Inventor files into 3dsmax 4.
To import Autodesk Inventor files into 3dsmax 4:
Start 3dsmax 4.
On the File menu, click Import.
In the Select File to Import dialog box, change the Files of Type to Autodesk Inventor (*.ipt,*.ipn,*.iam).
Locate and select the file to import.
Click Open.
Jochen Beiner
