In sehr seltenen Fällen kann es vorkommen, dass sich das SP-2 für Inventor R4 nicht installieren läßt. Es kann dann zu folgenden Fehlermeldungen (3) kommen :
"WinPatch encountered the following erros when verifying if the update can be applied. The following file does not match the file to be updated:
D:\Inventor4\bin\MustPerform.dll
This problem is caused by a corrupt or invalid MustPerfmon.dll file. To resolve this issue, you must replace the file.
Download the correct version of the MustPerfmon.dll file at
ftp://adeskftp.autodesk.com/prodsupp/inventor/MustPerfmon.dll
Overwrite the existing file on your system with the file you just downloaded.
2.Fehlermeldung zu:
D:\Inventor4\bin\InfoTip.dll
This problem is caused by a corrupt or invalid InfoTip.dll file. To resolve this issue, you must replace the file.
Download the correct version of the InfoTip.dll file at
ftp://adeskftp.autodesk.com/prodsupp/inventor/InfoTip.dll
3.Fehlermeldung zu:
D:\Inventor4\bin\ThView.dll
This problem is caused by a corrupt or invalid ThView.dll file. To resolve this issue, you must replace the file.
Download the correct version of the ThView.dll file at
ftp://adeskftp.autodesk.com/prodsupp/inventor/ThView.dll
You will now be able to install the Autodesk Inventor 4 Service Pack 2.
Bei allen Problemen mit Inventor kann es sich lohnen, mal einen Blick auf die PointA Knowledgebase(Product Support)unter
http://support01.autodesk.com/ViewAnswerworks.asp
zu werfen.
Jochen Beiner
[Diese Nachricht wurde von cadpraxis am 07. Juni 2001 editiert.]
