Hi.
Ich hab da was in der Wissensdatenbank bei Autodesk gefunden. Vielleicht hilft dir das weiter.
Gruß, LIDE.
Issue
You want to move all the title blocks used by the AMTITLE command to a network location.
Solution
For Mechanical Desktop® Release 4.0 Power Pack and AutoCAD® Mechanical 2000 (and Power Pack) software
Create a Gen folder at the required network location.
Copy the Dcl folder and its contents from the original installation folder and paste it in the new Gen folder.
Copy the Dwg folder and its contents from the original installation folder and paste it in the new Gen folder.
On the command line, enter amconfig to display the Mechanical Options dialog box.
On the Preferences tab, choose System.
In the System Editor dialog box, click the plus sign (+) next to the gen item to expand the content tree, and then select Paths.
In the right pane, right-click AltGeniusPath and choose Edit from the shortcut menu.
In the Modify/Create Configuration Object dialog box, enter the network path of the new Gen folder you created in step 1, and then choose OK.
Important: Do not enter Gen in the path. For example, if you created the following Gen folder in step 1:
H:\MCAD\Gen
Enter the path as follows:
H:\MCAD
Right-click Paths and choose New from the shortcut menu.
In the Modify/Create Configuration Object dialog box, specify AltDwgTitle as the name, and for the value enter the path to the network location of the new Dwg folder.
Important: Do not enter Dwg in the path.
For Mechanical Desktop Release 5 Power Pack, Autodesk® Mechanical Desktop® 6 Power Pack, AutoCAD Mechanical 2000i Power Pack, and AutoCAD Mechanical 6 Power Pack software
The list of available title blocks and formats for use with the AMTITLE command are stored in the drawing file itself.
Copy all of the title blocks and borders to the folder on the network drive.
Open the template file to be used for a project for which you want to make additional title blocks available.
Run the AMOPTIONS command.
In the Standards dialog box, double-click the drawing sheets icon located in the right pane.
To add additional title blocks, choose the Additional button located under Default Title Block in the Standard Sheet Properties dialog box. Do this for each additional title block you want to make available.
To add additional formats, choose the Additional button located under Default Paper Formats in the Standard Sheet Properties dialog box. Do this for each additional format you want to make available.
Choose OK in each dialog box to close all open dialog boxes.
Save the file as a template.
When you create new files from this template, they look to the files on the network that have been added to the list.
