We have some troubles with our CAD environment. The problem we hope you are able to help is as follows:
- We have access violation errors with crashes of AutoCAD
- Environment:
W2K
SP2 English
AutoCAD Mechanical Desktop V 6 German
W2K
Multi Language Pack
- Approximately 150 involved workstations
- Status of troubleshooting:
Problem occurs if user work in 2d-mode within MDT6
Problem does not occur if we switch off the MLP (Multi Language Pack)
Problems are not reproducible, they are sporadic
1 to 3 crashes per workstation and day
- Assumption
We assume that AutoCAD MDT6 does not properly work together with MLP. Bugs with other applications and MLP are currently not known.
- Workaround
We are able to switch off the MLP but we need this feature at all sites except English speaking ones
Error message: (address is different from message to message)
SYSTEMFEHLER: Unhandled Access Violation Reading 0x0004 Exception at 57a0dd5ch 10/08/2002 at 16:38:08.546 Zeichnung: C:Awork\bctc-82002-810.dwg
