So I have a problem, in company we have a control/quality check department and their job is to check connections from our reports to see that there is no mistakes
in production. For that case they need to check all wires, devices, etc. and they do a wiring check by going with our reports from connectors, devices etc. Now the problem is that our object is huge and we have a wire harnessing in our vehicle ( for example from one connector 5 wires are going to one side of a vehicle to one unit, and the next 10 are for other side of the vehicle..). Because we don't have pins sorted like a 5 wires are going from pins 1,2,3,4,5 to one unit ( it's not a pattern ) and we are using for instance 105 harting pin plug, it takes too much time for them to go from place to place because for pins 1,2,3 you'll be on one unit and then for pins 30,31,32 you need to go back again. That's why I was asked to see is it possible to sort plug or pin diagram by targets. For now, I wasn't able to find that option in sorting for these form types in templates or reports, but I known that connection list form has something on that clue. Did anyone had a similar problem and known is it possible to sort pins targets ( now what I see from eplan is that sorting is only available for pin properties or plug properties or placement or similar... but that doesn't help me currently).
Other word, I would like to sort plugs pin according with target DT!
I'm open for all suggestions and thankful for any idea !
VB
