soo habs hinbekommen, im bbsnotes forum von siemens hat mir jemand den entscheidenen tipp gegeben
Hi Tim. We have a function in the Open C toolkit that should do this:
UF_OBJ_ask_cre_mod_versions
Overview
Returns the version of the part in which the given object was created
and the version in which it was last modified. The version numbers
returned are from 1 to the highest version number of the part, unless
there is an error, in which case the version numbers are set to 0. The
UF_PART_<xxxx> routines which deal with part save histories can be
used to obtain information about the versions of a part.
This has also been wrapped for use in the .Net languages - see NXOpen.UF -> UFObj
-> AskCreModVersions().
There is a n Open C example posted in the Open Samples on the UGSolutions website
- just search for UF_OBJ_ask_cre_mod_versions.
Regards,
Steve
hab doch garnix gemacht .. außer den server neugestartet .. war das etwa falsch?
