| | | Gut zu wissen: Hilfreiche Tipps und Tricks aus der Praxis prägnant, und auf den Punkt gebracht für NX |
Thema: How Can I Set the Builder? (782 mal gelesen)
HappyJohn.Stephen Mitglied
Beiträge: 24 Registriert: 01.03.2009
erstellt am: 17. Mrz. 2009 10:29 <-- editieren / zitieren --> Unities abgeben:
Hello, In a cavity operation, when I set "cut pattern" to "follow periphery", cutting parameter "island cleanup" can be set to Yes or No. My code: cavityMillingBuilder1.CutPattern.CutPattern = CAM.CutPatternBuilder.Types.FollowPeriphery Dim DmBndBuilder1 As CAM.DmBndBuilder DmBndBuilder1.IslandCleanupStatus = True My question is how can I set the object DmBndBuilder1? Best regards, John
mseufert Moderator Freiberuflicher CAD/CAM Ingenieur
Beiträge: 2624 Registriert: 18.10.2005 HP Z420 WIN7 64 Win 10 UG NX6-1980 3D Printer Prusa MK2 S
erstellt am: 17. Mrz. 2009 15:38 <-- editieren / zitieren --> Unities abgeben: Nur für HappyJohn.Stephen
Hello John, do you want to create an Instance of the Builder? This should work the same way as with other Builders. When you record a journal while, for example, creating a box, you can see, how the Builder is used. Regards, Michael
erstellt am: 17. Mrz. 2009 17:58 <-- editieren / zitieren --> Unities abgeben:
Hello Michael, Thanks for your tips. For class cavityMillingBuilder, I can get an instance of it: operation1 = CAMSetup1.CAMOperationCollection.Create(nCGroup1, nCGroup2, tool1, nCGroup3, "mill_contour", "CAVITY_MILL", CAM.OperationCollection.UseDefaultName.False, Rtoolpathname) Dim cavityMillingBuilder1 As CAM.CavityMillingBuilder cavityMillingBuilder1 = CAMSetup1.CAMOperationCollection.CreateCavityMillingBuilder(operation1) But for class DmBndBuilder, there is no function CreateDmBndBuilder in CAMSetup1.CAMOperationCollection. So I don't know how to create an instance of the class DmBndBuilder. Best regards, John
| Technischer Produktdesigner (m/w/d) | Firmenbeschreibung ORANGE Engineering steht für Karriere mit innovativen Engineering-Projekten mit Standorten sowohl in Deutschland als auch in den Niederlanden. Zu unseren Kunden zählen erfolgreiche Unternehmen aus zahlreichen Branchen, durch die unsere Mitarbeiterinnen und Mitarbeiter an tagesaktuellen technologischen Entwicklungen beteiligt sind ? eine ausgezeichnete Perspektive für Ihre Karriere.... | Anzeige ansehen | Technischer Zeichner, Bauzeichner |
erstellt am: 22. Mrz. 2009 02:34 <-- editieren / zitieren --> Unities abgeben:
| Anzeige.:
