Bitte trage die vollständige Versionsnummer von NX und Dein Betriebssystem in der Systeminformation ein. Das erspart wiederholte Rückfragen.
Du solltest einen Wartungsvertrag abschließen und bei GTAC suchen
bzw. für NX10 einen neuen Call öffnen:
>>error code 800706be
GTAC PR 7314057
Update Part Familiy member: Excel COM error 800706be
... Using NX9.0.3 and Excel 2010 ...
The problem where COM error were raised when updating Part Family members unless they were update one at a time, has been investigated and the following has been found.
The problem where update family member causes a excel error, and which can be resolved by using part cleanup and delete spreadsheet data is being closed as Workaround.
Workaround:Workaround is already available to customer as mentioned in PR text:
1) Open the Part Family template, open the Part Family Spreadsheet and using Excel save a local copy of the worksheet as an .xlsx file
2) Close Excel and select "File > Utilities > Part Cleanup". Check "Delete Spreadsheet Data" and hit OK.
3) Select "Tools > Part Families > Edit Spreadsheet"
4) Delete the current content of the rebuilt worksheet
5) Open the .xlsx file from step 1 and copy/paste the contents into the Worksheet in Part Family. Close the .xlsx
6) Select "Tools > Add-Ins > Save Family"
7) Select "Tools > Add-Ins > Update Parts"
The root cause of such problems is generally some corruption of spreadheet data in part.
Rainer Schulze
