Siehe Online-Hilfe:
Startseite -> CAD -> Product and Manufacturing Information (PMI)
-> Dimensions -> Bemaßungs-Dialogleistenoptionen
Referenzen
Nur für PMI-Formelemente verfügbar.
Verknüpfte Objekte (Associated Objects)
Ermöglicht das Verknüpfen der Bemaßung mit einem oder mehreren geometrischen Objekten im Teil.
Da stelle ich erst einmal die Frage, was denn "PMI Formelemente" sind?
Nicht gerade aufschlussreich...
Vielleicht hilft das ja:
PMI associated objects
The Associated Objects command lets you explicitly capture your design intent by directly specifying the portions of the model to which the PMI pertains.
Selectable objects vary depending on the PMI type, but may include:
•Points
•Edges
•Faces
•Bodies
•Wireframe geometry
•Components
Example
If you have a note that specifies a particular finish for several faces, but you only want the note to point to one of the faces, you can attach the note to that face and use the Associated Objects option to associate all the faces to the note.
Whenever the note is queried or selected, its associated faces highlight in the graphics window and are listed in the query results.
Rainer Schulze
