  AutoCAD Architecture ACA (ADT)
  AutoCAD Architecture 2009 Product Update 2
Autor Thema:  AutoCAD Architecture 2009 Product Update 2 (2119 mal gelesen)
mazanek
CAD-Techniker
Sehen Sie sich das Profil von mazanek an!   Senden Sie eine Private Message an mazanek  Schreiben Sie einen Gästebucheintrag für mazanek
mein System:
Dell Precision T7600 (Xeon E5 2x 3.3Ghz 64MB RAM)
Windows 7 Pro. 64bit
Nvidia Quadro K420
Autdesk Building Design Suite Premium 2017
HP Designjet T1300 & T2300
erstellt am: 21. Okt. 2008 07:21    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hallo liebes Forum!
Hier der Link zum AutoCAD Architecture 2009 Product Update 2.
Hier der Link zum AutoCAD Architecture® 2009 Update 2 Readme
General Updates to AutoCAD Architecture
The following defects have been fixed in AutoCAD Architecture 2009 Update 2
Annotation scaling
    * Multi-view blocks inserted from user created tools did not scale properly when used in subsequent drawings or sessions.
Drawing management
    * Projects created from project templates did not inherit the correct sheet storage location property.
    * Projects created from project templates did not inherit sheet subset storage location information.
    * The application would occasionally crash when creating project details.
GBXML
    * Surfaces belonging to different walls would export with the same CadObjectId.
IFC
    * Spaces, railings, footings, and column objects might be exported with an incorrect object type identifier in some localized releases.
    * Half spaces would be imported as large modifiers.
    * Slab fascias and soffits would not properly export in some localized releases.
    * Level and elevation info would be created in reverse order when an IFC file was imported into a project.
    * Material sets applied to walls of type "Shared" would not export correctly.
Schedules
    * The schedule quantity column evaluated property values without first applying the property data format.
Wall objects and opening endcaps
    * Certain endcap configurations might cause walls to disappear in 3d isometric views.
    * Some walls might not draw completely at a locked z elevation.
    * Using "Add selected" for anchored doors, openings, and windows could cause an application crash in some circumstances.
    * Walls might fail to clean up properly across xrefs if the host drawing used different drawing units than the xref.
Miscellaneous
    * Tooltips would appear for AutoCAD entities even when ROLLOVERTIPS was set to zero.
    * Saving a drawing to the 2004 file format would take an exccessive amount of time.
    * Export to AutoCAD might cause an application crash in some circumstances.
The following defects were fixed with AutoCAD Architecture 2009 Update 1 and are also fixed in AutoCAD Architecture 2009 Update 2:
AModeler
    * The application might crash when cutting or refreshing sections or elevations containing certain structural members.
Drawing Management
    * For localized versions of AutoCAD Architecture, callouts and labels would occasionally fail to resolve when dropping views.
    * The application might crash when viewing the external references of a project drawing that was resaved as a different project drawing type.
    * It was not possible to drag a project entity from one file to another when hardware acceleration was enabled, if the host drawing did not use the 2d wireframe visual style.
    * The application might crash when plotting immediately after cancelling a previous plot job.
IFC
    * Fillet radii would not be imported reliably for certain parameteric profiles.
    * Parametric profiles without voids would not be imported reliably.
    * Spaces with clipping and holes would not import reliably.
    * Wall styles would not be reliably converted and mapped on import.
    * Curtain walls might not be import properly on localized versions of AutoCAD Architecture.
GBXML
    * gbXML would export a value 1000 times too large for AirChangesPerHour in metric drawings.
OMF
    * The application would occasionally crash on shutdown.
Wall Objects
    * The face of a wall might not draw correctly in isometric view for certain endcap configurations.
Display System
    * Autodesk Civil 3D users could end up with a style referencing a non-existent hatch.
Miscellaneous
    * Memory would not be released to Windows when closing a drawing.
ciao markus
- Der größte Bug sitzt immer VOR dem Bildschirm -
Markus Mazanek
Arch.E.Neversal Ziviltechniker GmbH
Maurer Lange Gasse 134
1230 Wien
