beide auf gleichem PC unter Win10 und beide2017
The Meldung:
The referenced vault does not exist.
Hier ein paar logs:
16.04.2016 20:15:50 ==== DataManagement.Common.Logging: DISABLED ====
16.04.2016 20:15:50 ==== Logging initiated: Core server version 22.0.48.0 ====
16.04.2016 20:15:50 Connectivity.Request.Common.RequestLibrary - RequestRuntimeStart()
16.04.2016 20:15:50 Connectivity.Request.Vault.RequestLibrary - RequestRuntimeStart()
16.04.2016 20:15:50 Connectivity.Request.Foundation.RequestLibrary - RequestRuntimeStart()
16.04.2016 20:15:50 Connectivity.Request.Document.RequestLibrary - RequestRuntimeStart()
16.04.2016 20:15:52 There are no vaults on this server. Would you like to create one now?
16.04.2016 20:15:58 Reading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSchema.cfg'
16.04.2016 20:15:58 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSchema.cfg'
16.04.2016 20:15:58 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSchema.cfg' - section 'VaultKVMSchemaScripts'
16.04.2016 20:15:58 Executing SQL script 'Connectivity.Core.Database.Sql.VersionSchema.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:58 Executing SQL script 'Connectivity.Core.Database.Sql.CoreReplicationSchema.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:58 Executing SQL script 'Connectivity.Core.Database.Sql.MasterSchema.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:58 Executing SQL script 'Connectivity.Core.Database.Sql.WorkflowMasterSchema.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:58 DONE - loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSchema.cfg'
16.04.2016 20:15:58 Reading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterDataAccess.cfg'
16.04.2016 20:15:58 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterDataAccess.cfg'
16.04.2016 20:15:58 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterDataAccess.cfg' - section 'VaultKVMAccessObjectsScripts'
16.04.2016 20:15:58 Executing SQL script 'Connectivity.Core.Database.Sql.VersionSprocs.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:58 Executing SQL script 'Connectivity.Core.Database.Sql.CoreReplicationSprocs.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:58 Executing SQL script 'Connectivity.Core.Database.Sql.MasterTypes.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:58 Executing SQL script 'Connectivity.Core.Database.Sql.MasterSprocs.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:59 Executing SQL script 'Connectivity.Core.Database.Sql.WorkflowMasterSprocs.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:59 Executing SQL script 'Connectivity.Core.Database.Sql.MasterSprocs_Replication.sql' from assembly 'Connectivity.Platform'
16.04.2016 20:15:59 DONE - loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterDataAccess.cfg'
16.04.2016 20:15:59 Reading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSystemData.cfg'
16.04.2016 20:15:59 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSystemData.cfg'
16.04.2016 20:15:59 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSystemData.cfg' - section 'VaultUsers'
16.04.2016 20:15:59 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSystemData.cfg' - section 'CoreMasterOptions'
16.04.2016 20:15:59 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSystemData.cfg' - section 'DocumentMasterOptions'
16.04.2016 20:15:59 Loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSystemData.cfg' - section 'Libraries'
16.04.2016 20:15:59 DONE - loading configuration 'C:\Program Files\Autodesk\ADMS 2017\Server\VaultScripts\Config\VaultAppMasterSystemData.cfg'
16.04.2016 20:16:10 System.NotSupportedException: Windows Authentication is not supported by this version of the Autodesk data management server.
bei Connectivity.Application.VaultManager.SecurityService.CheckWinAuth()
bei Connectivity.Application.VaultManager.SecurityService.WinAuthSignIn()
bei Connectivity.Application.VaultManager.SignInForm.m_okButton_Click(Object sender, EventArgs e)
16.04.2016 20:17:38 Connectivity.Request.Common.RequestLibrary - RequestRuntimeStop()
16.04.2016 20:17:38 Connectivity.Request.Vault.RequestLibrary - RequestRuntimeStop()
16.04.2016 20:17:38 Connectivity.Request.Foundation.RequestLibrary - RequestRuntimeStop()
16.04.2016 20:17:38 Connectivity.Request.Document.RequestLibrary - RequestRuntimeStop()
16.04.2016 22:42:47 ==== DataManagement.Common.Logging: DISABLED ====
16.04.2016 22:42:47 ==== Logging initiated: Core server version 22.0.48.0 ====
16.04.2016 22:42:47 Connectivity.Request.Common.RequestLibrary - RequestRuntimeStart()
16.04.2016 22:42:47 Connectivity.Request.Vault.RequestLibrary - RequestRuntimeStart()
16.04.2016 22:42:47 Connectivity.Request.Foundation.RequestLibrary - RequestRuntimeStart()
16.04.2016 22:42:47 Connectivity.Request.Document.RequestLibrary - RequestRuntimeStart()
16.04.2016 22:42:49 Checking if a migration is necessary.
16.04.2016 22:42:52 All vaults and libraries have already been migrated.
16.04.2016 22:43:13 Connectivity.Request.Common.RequestLibrary - RequestRuntimeStop()
16.04.2016 22:43:13 Connectivity.Request.Vault.RequestLibrary - RequestRuntimeStop()
16.04.2016 22:43:13 Connectivity.Request.Foundation.RequestLibrary - RequestRuntimeStop()
16.04.2016 22:43:13 Connectivity.Request.Document.RequestLibrary - RequestRuntimeStop()
[Diese Nachricht wurde von Wodan2017 am 20. Apr. 2016 editiert.]
