Hallo Leute, ich habe hier ein dickes Problem bei der Wiederherstellung einer Datensicherung vom Vault. Die Wiederherstellung bricht immer mit einer Fehlermeldung ab.
Kann mir da irgendjemand helfen?
Hier sind die Auszüge der Log-Dateien:
Vault-Server:
24.03.2006 11:48:48: Connectivity.Application.VaultManager.ServiceException: RestoreDBFailed ---> Connectivity.Core.Util.CoreException: RestoreDBFailed ---> System.NullReferenceException: Object reference not set to an instance of an object.
at Connectivity.Core.Services.KnowledgeVaultService.ValidateRestoreContents(String sContents, Hashtable hFilestores, String& kvMasterName)
at Connectivity.Core.Services.KnowledgeVaultService.RestoreData(DirectoryInfo fromDirectory, DirectoryInfo toFSDirectory, DirectoryInfo toDBDirectory, String user, String pass, Boolean& success)
at Connectivity.Core.Services.KnowledgeVaultService.RestoreAll(String restorePath, String toFSLocation, String toDBLocation, String user, String pass)
--- End of inner exception stack trace ---
Server stack trace:
at Connectivity.Core.Services.KnowledgeVaultService.Restore(String restorePath, String toFSLocation, String toDBLocation, String user, String pass)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Application.VaultManager.KnowledgeVaultService.Restore(String restorePath, String toFSLocation, String toDBLocation, String user, String pass)
at Connectivity.Application.VaultManager.RestoreVaultCommand.DoRestore(String restorePath, Boolean isRestoreDirectory, LoginInfo dbLogin, String toFSLocation, String toDBLocation)
SQL-Server:
2006-03-24 10:56:12.31 server Microsoft SQL Server 2000 - 8.00.760 (Intel X86)
Dec 17 2002 14:22:05
Copyright (c) 1988-2003 Microsoft Corporation
Desktop Engine on Windows NT 5.1 (Build 2600: Service Pack 2)
2006-03-24 10:56:12.31 server Copyright (C) 1988-2002 Microsoft Corporation.
2006-03-24 10:56:12.31 server Alle Rechte vorbehalten.
2006-03-24 10:56:12.31 server Serverprozess-ID ist 3344.
2006-03-24 10:56:12.31 server Protokolliert SQL Server-Meldungen in Datei 'C:\Programme\Microsoft SQL Server\MSSQL$AUTODESKVAULT\LOG\ERRORLOG'.
2006-03-24 10:56:12.31 server SQL Server startet mit Prioritätsklasse 'normal' (2 CPUs vorgefunden).
2006-03-24 10:56:12.53 server SQL Server wurde für die Verarbeitung im thread-Modus konfiguriert.
2006-03-24 10:56:12.54 server Die dynamic-Sperrenreservierung wird verwendet. [500] Sperrenblöcke, [1000] Sperrenbesitzerblöcke.
2006-03-24 10:56:12.65 spid2 Startet Datenbank 'master'.
2006-03-24 10:56:13.12 server Verwendet 'SSNETLIB.DLL', Version '8.0.766'.
2006-03-24 10:56:13.12 spid5 Startet Datenbank 'model'.
2006-03-24 10:56:13.15 spid2 Servername ist 'NOGGERXP\AUTODESKVAULT'.
2006-03-24 10:56:13.15 spid2 Skipping startup of clean database id 4
2006-03-24 10:56:13.18 server SQL Server überwacht Shared Memory.
2006-03-24 10:56:13.18 server SQL Server ist bereit für Clientverbindungen
2006-03-24 10:56:13.26 spid5 Löscht tempdb-Datenbank.
2006-03-24 10:56:13.90 spid5 Startet Datenbank 'tempdb'.
2006-03-24 10:56:14.56 spid2 Wiederherstellung abgeschlossen.
2006-03-24 10:56:14.56 spid2 SQL global counter collection task is created.
2006-03-24 10:56:58.18 spid51 Startet Datenbank 'KnowledgeVaultMaster'.
2006-03-24 10:56:58.67 spid51 Startet Datenbank 'KnowledgeVaultMaster'.
2006-03-24 10:57:05.14 spid54 Startet Datenbank 'Vault'.
2006-03-24 10:57:05.39 spid54 Startet Datenbank 'Vault'.
2006-03-24 11:17:36.49 spid51 BackupDiskFile: penMedia: Fehler von Sicherungsmedium '\\Kon1\vault-backup\VaultBackup_2006_03_23_10_45_50_\databases\KnowledgeVaultMaster_dbbak' bei open. Betriebssystemfehler = 5(Zugriff verweigert).
2006-03-24 11:44:36.56 spid51 BackupDiskFile: penMedia: Fehler von Sicherungsmedium '\\Kon1\vault-backup\VaultBackup_2006_03_24_11_14_57_\databases\KnowledgeVaultMaster_dbbak' bei open. Betriebssystemfehler = 5(Zugriff verweigert).
