  PTC Creo Elements/Direct Modeling
  Imperial Fasteners
Autor Thema:  Imperial Fasteners (1240 mal gelesen)
CSPalmer84
Illustrator, Programmer
Sehen Sie sich das Profil von CSPalmer84 an!   Senden Sie eine Private Message an CSPalmer84  Schreiben Sie einen Gästebucheintrag für CSPalmer84
Dell T1700
3.4 Ghz
16 Gb
erstellt am: 17. Jul. 2017 17:17    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
sd-machine-fasteners.lsp
sd-machine-fasteners-listings.lsp
sd-machine-threads.lsp
These functions are used to create Imperial threaded Bolts Nuts and Washers. Granted, they aren't very detailed, but its still easier then drawing them manually. I also provided a "simple" PDM chart...... it's based on what we used here since we don't use PTC's pdm, so please take it with a grain of salt. Also please note that you need to load sd-machine-fasteners.lsp and sd-machine-threads.lsp for these to work; by default the PDM I made is disabled. The initial selection of 'Select Face' and 'Center Point' are optional, but they're used to move part into position. One last note, the double sided stud has an illustration picture for its dialog.
The sword alone does not give you the courage and strength you will need on your journey
[Diese Nachricht wurde von CSPalmer84 am 17. Jul. 2017 editiert.]
