Code:
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32Namespace InventorAddinTest
<ProgIdAttribute("InventorAddinTest.StandardAddInServer"), _
GuidAttribute(g_simpleAddInClientID)> _
Public Class StandardAddInServer
Implements Inventor.ApplicationAddInServer
'* The two declarations below are related to adding buttons to Inventor's UI.
'* They can be deleted if this add-in doesn't have a UI and only runs in the
'* background handling events.
' Declaration of the object for the UserInterfaceEvents to be able to handle
' if the user resets the ribbon so the button can be added back in.
Private WithEvents m_uiEvents As UserInterfaceEvents
' Declaration of the button definition with events to handle the click event.
' For additional commands this declaration along with other sections of code
' that apply to the button can be duplicated from this example.
Private WithEvents m_sampleButton As ButtonDefinition
#Region "ApplicationAddInServer Members"
' This method is called by Inventor when it loads the AddIn. The AddInSiteObject provides access
' to the Inventor Application object. The FirstTime flag indicates if the AddIn is loaded for
' the first time. However, with the introduction of the ribbon this argument is always true.
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
Try
' Initialize AddIn members.
g_inventorApplication = addInSiteObject.Application
' Connect to the user-interface events to handle a ribbon reset.
m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
'* The remaining code in this Sub is all for adding the add-in into Inventor's UI.
'* It can be deleted if this add-in doesn't have a UI and only runs in the
' Create the button definition using the CreateButtonDefinition function to simplify this step.
m_sampleButton = Utilities.CreateButtonDefinition("SET" & vbCr & "Prop", "niftyCommandID", "", "ButtonResources\SampleButton")
' Add to the user interface, if it's the first time.
' If this add-in doesn't have a UI but runs in the background listening
' to events, you can delete this.
If firstTime Then
AddToUserInterface()
End If
Catch ex As Exception
MsgBox("Unexpected failure in the activation of the add-in ""InventorAddinTest""" & vbCrLf & vbCrLf & ex.Message)
End Try
End Sub
' This method is called by Inventor when the AddIn is unloaded. The AddIn will be
' unloaded either manually by the user or when the Inventor session is terminated.
Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
' Release objects.
m_sampleButton = Nothing
m_uiEvents = Nothing
g_inventorApplication = Nothing
System.GC.Collect()
System.GC.WaitForPendingFinalizers()
End Sub
' This property is provided to allow the AddIn to expose an API of its own to other
' programs. Typically, this would be done by implementing the AddIn's API
' interface in a class and returning that class object through this property.
' Typically it's not used, like in this case, and returns Nothing.
Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation
Get
Return Nothing
End Get
End Property
Public Property ThisApplication As Application
' Note:this method is now obsolete, you should use the
' ControlDefinition functionality for implementing commands.
Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand
' Not used.
End Sub
#End Region
#Region "User interface definition"
' Adds whatever is needed by this add-in to the user-interface. This is
' called when the add-in loaded and also if the user interface is reset.
Private Sub AddToUserInterface()
' This sample code illustrates creating a button on a new panel of the Tools tab of
' the Part ribbon. You'll need to change this to create the UI that your add-in needs.
' Get the part ribbon.
Dim partRibbon As Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item("Part")
' Get the assembly ribbon.
Dim assemblyRibbon As Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item("Assembly")
' Get the drawing ribbon.
Dim DrawingRibbon As Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item("Drawing")
' Get the "Tools" tab.
Dim toolsTab As RibbonTab = partRibbon.RibbonTabs.Item("id_TabTools")
Dim toolsTabassembly As RibbonTab = assemblyRibbon.RibbonTabs.Item("id_TabTools")
Dim toolsTabdrawing As RibbonTab = DrawingRibbon.RibbonTabs.Item("id_TabTools")
' Get the "Model" tab from the part ribbon.
'Dim modelTab As Inventor.RibbonTab = assemblyRibbon.RibbonTabs.Item("id_TabModel")
' Get the "Modify" panel from the model tab.
'Dim modifyPanel As Inventor.RibbonPanel = modelTab.RibbonPanels.Item("id_PanelP_ModelModify")
Dim m_bulgeButton As ButtonDefinition = Nothing
' Add the button to the modify panel.
'modifyPanel.CommandControls.AddButton(m_bulgeButton, True)
Dim oUserInterfaceManager As UserInterfaceManager
oUserInterfaceManager = g_inventorApplication.UserInterfaceManager
Dim oInterfaceStyle As InterfaceStyleEnum
oInterfaceStyle = oUserInterfaceManager.InterfaceStyle
' Check to see if the "MySample" panel already exists and create it if it doesn't.
Dim customPanel As RibbonPanel = Nothing
Dim customPanelassembly As RibbonPanel = Nothing
Dim customPaneldrawing As RibbonPanel = Nothing
Try
customPanel = toolsTab.RibbonPanels.Item("MyMFP")
customPanelassembly = toolsTabassembly.RibbonPanels.Item("MyMFP")
customPaneldrawing = toolsTabdrawing.RibbonPanels.Item("MyMFP")
End Try
If customPanel Is Nothing Then
' Create a new panel.
customPanel = toolsTab.RibbonPanels.Add("MFP", "MyMFP", g_addInClientID)
End If
If customPanelassembly Is Nothing Then
customPanelassembly = toolsTabassembly.RibbonPanels.Add("MFP", "MyMFP", g_addInClientID)
End If
If customPaneldrawing Is Nothing Then
customPaneldrawing = toolsTabdrawing.RibbonPanels.Add("MFP", "MyMFP", g_addInClientID)
End If
Dim firstTime As Boolean = Nothing
If firstTime Then
' Get the part features command bar.
Dim partCommandBar As Inventor.CommandBar
partCommandBar = g_inventorApplication.UserInterfaceManager.CommandBars.Item(
"PMxPartFeatureCmdBar")
Dim m_featureCountButtonDef As ButtonDefinition = Nothing
' Add a button to the command bar, defaulting to the end position.
partCommandBar.Controls.AddButton(m_featureCountButtonDef)
End If
' Add a button.
If Not m_sampleButton Is Nothing Then
customPanel.CommandControls.AddButton(m_sampleButton, True)
customPanelassembly.CommandControls.AddButton(m_sampleButton, True)
customPaneldrawing.CommandControls.AddButton(m_sampleButton, True)
End If
End Sub
Private Sub m_uiEvents_OnResetRibbonInterface(Context As NameValueMap) Handles m_uiEvents.OnResetRibbonInterface
' The ribbon was reset, so add back the add-ins user-interface.
End Sub
' Sample handler for the button.
Private Sub m_sampleButton_OnExecute(Context As NameValueMap) Handles m_sampleButton.OnExecute
SetPROP()
End Sub
#End Region
End Class
End Namespace
Public Module Globals
' Inventor application object.
Public g_inventorApplication As Inventor.Application
' The unique ID for this add-in. If this add-in is copied to create a new add-in
' you need to update this ID along with the ID in the .manifest file, the .addin file
' and create a new ID for the typelib GUID in AssemblyInfo.vb
Public Const g_simpleAddInClientID As String = "647237d2-0e27-486f-b901-6903c6913aab"
Public Const g_addInClientID As String = "{" & g_simpleAddInClientID & "}"
End Module
