Code:
Public Sub PDF()
On Error Resume Next
If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
Exit Sub
End If
Dim Pfad As String
Pfad = CurDir & "\" If Dir(Pfad & "PDF", vbDirectory) = "PDF" Then
'MsgBox "Ordner ''PDF'' ist vorhanden!"
GoTo Sprung
Else
MkDir "PDF"
'MsgBox "Ordner ''PDF'' wurde in folgendem Pfad angelegt: " & Pfad
End If
Sprung:
Dim oDoc As Inventor.DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oFileName As String
oFileName = oDoc.FullDocumentName
Dim oArray() As String
oArray = Split(oFileName, "\")
If oDoc.FullFileName = "" Then
MsgBox "Bitte zuerst die Zeichnung speichern... "
Exit Sub
End If
Dim sName As String
Dim i As Integer
sName = oArray(LBound(oArray))
For i = 1 To UBound(oArray) - 1
sName = sName & "\" & oArray(i)
Next
sName = sName & "\PDF\" & (oArray(UBound(oArray)))
Dim Msg
Err.Clear
If Err.Number <> 0 Then
Msg = "KeineZeichnung "
MsgBox Msg
End If
oDoc.SheetSettings.SheetColor = ThisApplication.TransientObjects.CreateColor(255, 255, 255)
' Get the PDF translator Add-In.
Dim PDFAddIn As TranslatorAddIn
Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' Options for drawings...
oOptions.Value("All_Color_AS_Black") = 0
'oOptions.Value("Remove_Line_Weights") = 0
'oOptions.Value("Vector_Resolution") = 400
'oOptions.Value("Sheet_Range") = kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
oDataMedium.FileName = Replace(sName, ".idw", ".pdf")
'Publish document.
Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Dim oFarbe As DrawingDocument
Set oFarbe = ThisApplication.ActiveDocument
oFarbe.SheetSettings.SheetColor = ThisApplication.TransientObjects.CreateColor(255, 255, 255)
End Sub
