Code:
Public Sub PDF() Dim oDoc As DrawingDocument
Dim Msg
' If an error occurs, construct an error message
On Error Resume Next ' Defer error handling.
Err.Clear
'Err.Raise 6 ' Generate an "Overflow" error.
' Check for error, then show message.
If Err.Number <> 0 Then
Msg = "KeineZeichnung "
MsgBox Msg
End If
Set oDoc = ThisApplication.ActiveDocument
oDoc.SheetSettings.SheetColor = ThisApplication.TransientObjects.CreateColor(255, 255, 255)
' Get the PDF translator Add-In.
Dim PDFAddIn As TranslatorAddIn
Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' Options for drawings...
oOptions.Value("All_Color_AS_Black") = 0
'oOptions.Value("Remove_Line_Weights") = 0
'oOptions.Value("Vector_Resolution") = 400
'oOptions.Value("Sheet_Range") = kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
'Set the destination file name
'oDataMedium.FileName = "c:\temp\test.pdf" <------
' erzeugt ein pdf mit gleichem Namen im gleiche Verzeichnis wie die *.idw
oDataMedium.FileName = Replace(oDoc.FullDocumentName, ".idw", ".pdf")
'Publish document.
Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Dim oFarbe As DrawingDocument
Set oFarbe = ThisApplication.ActiveDocument
oFarbe.SheetSettings.SheetColor = ThisApplication.TransientObjects.CreateColor(255, 255, 255)
End Sub
