Code:
Public Sub TestSelection()
' Create a new clsSelect object.
Dim oSelect As New clsSelect ' Call the pick method of the clsSelect object and set
' the filter to pick any face.
Dim oFace As Face
Set oFace = oSelect.Pick(kPartFaceFilter)
' Check to make sure an object was selected.
If Not oFace Is Nothing Then
' Display the area of the selected face.
MsgBox "Face area: " & oFace.Evaluator.Area & " cm^2"
End If
End Sub
' The declarations and functions below need to be copied into
' a class module whose name is "clsSelect". The name can be
' changed but you'll need to change the declaration in the
' calling function "TestSelection" to use the new name.
' Declare the event objects
Private WithEvents oInteractEvents As InteractionEvents
Private WithEvents oSelectEvents As SelectEvents
' Declare a flag that's used to determine when selection stops.
Private bStillSelecting As Boolean
Public Function Pick(filter As SelectionFilterEnum) As Object
' Initialize flag.
bStillSelecting = True
' Create an InteractionEvents object.
Set oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
' Ensure interaction is enabled.
oInteractEvents.InteractionDisabled = False
' Set a reference to the select events.
Set oSelectEvents = oInteractEvents.SelectEvents
' Set the filter using the value passed in.
oSelectEvents.AddSelectionFilter filter
' Start the InteractionEvents object.
oInteractEvents.Start
' Loop until a selection is made.
Do While bStillSelecting
DoEvents
Loop
' Get the selected item. If more than one thing was selected,
' just get the first item and ignore the rest.
Dim oSelectedEnts As ObjectsEnumerator
Set oSelectedEnts = oSelectEvents.SelectedEntities
If oSelectedEnts.Count > 0 Then
Set Pick = oSelectedEnts.Item(1)
Else
Set Pick = Nothing
End If
' Stop the InteractionEvents object.
oInteractEvents.Stop
' Clean up.
Set oSelectEvents = Nothing
Set oInteractEvents = Nothing
End Function
Private Sub oInteractEvents_OnTerminate()
' Set the flag to indicate we're done.
bStillSelecting = False
End Sub
Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
End Sub
