Code:
Public Sub doertie()' Declare the Application object
Dim oApplication As Inventor.Application
' Obtain the Inventor Application object.
' This assumes Inventor is already running.
Set oApplication = GetObject(, "Inventor.Application")
' Set a reference to the active document.
' This assumes a document is open.
Dim oDoc As Document
Set oDoc = oApplication.ActiveDocument
If oApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
MsgBox ("In IDW nicht möglich.")
Exit Sub
End If
If oApplication.ActiveDocument.DocumentType = kPresentationDocumentObject Then
MsgBox ("In IPN nicht möglich.")
Exit Sub
End If
If oApplication.ActiveEditObject.DocumentType = kPartDocumentObject Then
oDoc.Dirty = True
Else
Dim oAsm As AssemblyDocument
Set oAsm = ThisApplication.ActiveDocument
ForAllComponents oAsm.ComponentDefinition.Occurrences, oDoc
End If
End Sub
Sub ForAllComponents(oObjOccs As ComponentOccurrences, oDoc As Document)
Dim oObjOcc As ComponentOccurrence
Dim oaeo As Object
For Each oObjOcc In oObjOccs
oObjOcc.Edit
Set oaeo = oApplication.ActiveEditObject
oaeo.Dirty = True
If Err.Number <> 0 Then
Err.Number = 0
GoTo NEXTCOMP
End If
ThisApplication.CommandManager.[_StartCommand] 43312
NEXTCOMP:
ForAllComponents oObjOcc.SubOccurrences, oDoc
Next
End Sub
