zu den Hotfixes von Inventor habe ich folgende Frage:
Ist ServicePack 1 die Zusammenfassung von Punkt 1 bis 10 und
Ist ServicePack 2 die Zusammenfassung von Punkt 12 bis 18 ?
im Internet findet man folgende Liste unter http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=4189376
Autodesk Inventor® Professional 9
22.Hotfix - Inventor May Resolve to Files
Located Outside of the Project File
21.Hotfix - Deleting a Feature Can Cause
Unrelated Workaxes to be Deleted
20.Hotfix - OLE Objects not visible in Stand Alone Design Tracking
19.Autodesk Inventor® Professional 9 Service Pack 2
18.Update to Inventor Style Library Colors
17.Hotfix - Heap Errors opening IDW's & prompted
text values changing order
16.Problems with some hose styles in AIP9 (Simplified Chinese only)
15.Inventor Performance Degradation Troubleshooting Tips
14.Hotfix - Heap Errors when opening IDW files
in Autodesk Inventor 9
13.Hotfix - Find Files not working in Design Assistant
12.Hotfix - problems with Stress Analysis Report Generator
(Traditional Chinese)
11.Autodesk Inventor® Professional 9 Service Pack 1
10.Autodesk Mechanical Desktop 2005
(Autodesk Inventor Professional 9) Service Pack 1
9.Hotfix - LiveUpdate Does Not Work on Localized Inventor 9 Products
8.Hotfix - Drawing Property displayed in English (German Only)
7.Hotfix - Package Files cannot be viewed in the
Streamline Express Viewer 5
6.Hotfix - 3D DWF publish from weldment assembly can cause instabilty
5.Hotfix - Unable to save IDW files create in
previous versions of Autodesk Inventor
4.Hotfix - Mirror or copy a part that is constrained to another
causes instability
3.Configuration file parse error occurs when users
attempt to import (Japanese only)
2.Hotfix - Constraints not honored during drag
1.Autodesk Vault 3 Configuration Guide: Working with Remote File
MFG
