Hallo hubtexao!
Sieh dir mal dieses Bsp aus der Hilfe an, der Bereich mit 'FoldFeature' dürfte für dich interessant sein, habe es aber selbst nicht getestet.
Public Sub SheetMetalFeatureDisplay()
' Set a reference to the sheet metal document.
' This assumes a part document is active.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
' Make sure the document is a sheet metal document.
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox "A sheet metal document must be open."
Exit Sub
End If
' Get the sheet metal component definition. Because this is a part document whose
' sub type is sheet metal, the document will return a SheetMetalComponentDefinition
' instead of a PartComponentDefinition.
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
' Iterate through the features looking specifically for sheet metal features.
Dim oFeature As PartFeature
For Each oFeature In oSheetMetalCompDef.Features
Select Case oFeature.Type
Case kFaceFeatureObject
Dim oFaceFeature As FaceFeature
Set oFaceFeature = oFeature
Debug.Print "Face Feature: " & oFaceFeature.Name
Debug.Print " Adaptive: " & oFaceFeature.Adaptive
Debug.Print " Face Count: " & oFaceFeature.Faces.Count
Debug.Print " HealthStatus: " & oFaceFeature.HealthStatus
Debug.Print " RangeBox: (" & Format(oFaceFeature.RangeBox.MinPoint.X, "0.00000") & ", " & _
Format(oFaceFeature.RangeBox.MinPoint.Y, "0.00000") & ", " & _
Format(oFaceFeature.RangeBox.MinPoint.Z, "0.00000") & ")-(" & _
Format(oFaceFeature.RangeBox.MaxPoint.X, "0.00000") & ", " & _
Format(oFaceFeature.RangeBox.MaxPoint.Y, "0.00000") & ", " & _
Format(oFaceFeature.RangeBox.MaxPoint.Z, "0.00000") & ")"
Debug.Print " Suppressed: " & oFaceFeature.Suppressed
Case kContourFlangeFeatureObject
Dim oContourFlangeFeature As ContourFlangeFeature
Set oContourFlangeFeature = oFeature
Debug.Print "Contour Flange Feature: " & oContourFlangeFeature.Name
Debug.Print " Adaptive: " & oContourFlangeFeature.Adaptive
Debug.Print " Face Count: " & oContourFlangeFeature.Faces.Count
Debug.Print " HealthStatus: " & oContourFlangeFeature.HealthStatus
Debug.Print " Suppressed: " & oContourFlangeFeature.Suppressed
Case kCutFeatureObject
Dim oCutFeature As CutFeature
Set oCutFeature = oFeature
Debug.Print "Cut Feature: " & oCutFeature.Name
Debug.Print " Adaptive: " & oCutFeature.Adaptive
Debug.Print " Face Count: " & oCutFeature.Faces.Count
Debug.Print " HealthStatus: " & oCutFeature.HealthStatus
Debug.Print " Suppressed: " & oCutFeature.Suppressed
Case kFlangeFeatureObject
Dim oFlangeFeature As FlangeFeature
Set oFlangeFeature = oFeature
Debug.Print "Flange Feature: " & oFlangeFeature.Name
Debug.Print " Adaptive: " & oFlangeFeature.Adaptive
Debug.Print " Face Count: " & oFlangeFeature.Faces.Count
Debug.Print " HealthStatus: " & oFlangeFeature.HealthStatus
Debug.Print " Suppressed: " & oFlangeFeature.Suppressed
Case kHemFeatureObject
Dim oHemFeature As HemFeature
Set oHemFeature = oFeature
Debug.Print "Hem Feature: " & oHemFeature.Name
Debug.Print " Adaptive: " & oHemFeature.Adaptive
Debug.Print " Face Count: " & oHemFeature.Faces.Count
Debug.Print " HealthStatus: " & oHemFeature.HealthStatus
Debug.Print " Suppressed: " & oHemFeature.Suppressed
Case kFoldFeatureObject
Dim oFoldFeature As FoldFeature
Set oFoldFeature = oFeature
Debug.Print "Fold Feature: " & oFoldFeature.Name
Debug.Print " Adaptive: " & oFoldFeature.Adaptive
Debug.Print " Face Count: " & oFoldFeature.Faces.Count
Debug.Print " HealthStatus: " & oFoldFeature.HealthStatus
Debug.Print " Suppressed: " & oFoldFeature.Suppressed
Case kCornerFeatureObject
Dim oCornerFeature As CornerFeature
Set oCornerFeature = oFeature
Debug.Print "Corner Seam Feature: " & oCornerFeature.Name
Debug.Print " Adaptive: " & oCornerFeature.Adaptive
Debug.Print " Face Count: " & oCornerFeature.Faces.Count
Debug.Print " HealthStatus: " & oCornerFeature.HealthStatus
Debug.Print " Suppressed: " & oCornerFeature.Suppressed
Case kBendFeatureObject
Dim oBendFeature As BendFeature
Set oBendFeature = oFeature
Debug.Print "Bend Feature: " & oBendFeature.Name
Debug.Print " Adaptive: " & oBendFeature.Adaptive
Debug.Print " Face Count: " & oBendFeature.Faces.Count
Debug.Print " HealthStatus: " & oBendFeature.HealthStatus
Debug.Print " Suppressed: " & oBendFeature.Suppressed
Case kCornerRoundFeatureObject
Dim oCornerRoundFeature As CornerRoundFeature
Set oCornerRoundFeature = oFeature
Debug.Print "Corner Round Feature: " & oCornerRoundFeature.Name
Debug.Print " Adaptive: " & oCornerRoundFeature.Adaptive
Debug.Print " Face Count: " & oCornerRoundFeature.Faces.Count
Debug.Print " HealthStatus: " & oCornerRoundFeature.HealthStatus
Debug.Print " Suppressed: " & oCornerRoundFeature.Suppressed
Case kCornerChamferFeatureObject
Dim oCornerChamferFeature As CornerChamferFeature
Set oCornerChamferFeature = oFeature
Debug.Print "Corner Chamfer Feature: " & oCornerChamferFeature.Name
Debug.Print " Adaptive: " & oCornerChamferFeature.Adaptive
Debug.Print " Face Count: " & oCornerChamferFeature.Faces.Count
Debug.Print " HealthStatus: " & oCornerChamferFeature.HealthStatus
Debug.Print " Suppressed: " & oCornerChamferFeature.Suppressed
Case kPunchToolFeatureObject
Dim oPunchToolFeature As PunchToolFeature
Set oPunchToolFeature = oFeature
Debug.Print "Punch Tool Feature: " & oPunchToolFeature.Name
Debug.Print " Adaptive: " & oPunchToolFeature.Adaptive
Debug.Print " Face Count: " & oPunchToolFeature.Faces.Count
Debug.Print " HealthStatus: " & oPunchToolFeature.HealthStatus
Debug.Print " Suppressed: " & oPunchToolFeature.Suppressed
Case Else
Debug.Print "Non Sheetmetal Feature: " & oFeature.Name
Debug.Print " Adaptive: " & oFeature.Adaptive
Debug.Print " Face Count: " & oFeature.Faces.Count
Debug.Print " HealthStatus: " & oFeature.HealthStatus
Debug.Print " Suppressed: " & oFeature.Suppressed
End Select
Next
End Sub
LieGrü Heijo
EVERYTHING IS DESIGNED.
