gar nicht, da für die Integerdarstellung bloß 32 bit zur Verfügung stehen.. aus F1 :
Integers are whole numbers that do not contain a decimal point. AutoLISP integers are 32-bit signed numbers with values ranging from +2,147,483,647 to -2,147,483,648. (Note, however, that the getint function only accepts 16-bit numbers ranging from +32767 to -32678.) When you explicitly use an integer in an AutoLISP expression, that value is known as a constant. Numbers such as 2, -56, and 1,200,196 are valid AutoLISP integers.
If you enter a number that is greater than the maximum integer allowed (resulting in integer overflow), AutoLISP converts the integer to a real number.
also , bei 2147483647 ist Schluß, danach wird in Real konvertiert. -> _$ 2147483648 --> 2.14748e+009
aber lies selbst
Wenns nur um die Ausgabe geht --> rtos
- Thomas -
