Thema: Führung mit Dialogbox (477 mal gelesen)
Kramer24 Ehrenmitglied V.I.P. h.c. Architekt
Beiträge: 5881 Registriert: 09.11.2001
erstellt am: 15. Mai. 2006 11:37 <-- editieren / zitieren --> Unities abgeben:
Hallo, ich bin schon lange auf der Suche nach einem Tool, mit dem ich voergefertigte Texte via Dialogbox mit einer assoziativen Führung in meine Zeichnung einfügen kann. Habe jetzt durch Zufall so etwas ähnliches gefunden. ABER: Hier wird der Text über "_dim" -> "_leader" eingefügt. Schade! BTN! Code: ;; Note with leader by Ken Jolly 1997 ;; Web Site http://members.aol.com/autolisper/index.htm ;; E-mail Bilgeslime@aol.com ; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED ; WARRANTY. ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR ; PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED. ; **************************************************************** (defun C:NOTE ( ) (setq args '( )) (setvar "CMDECHO" 0) (setvar "BLIPMODE" 0) (setq NAMES '( "1/4 W x 1 1/4 DP SLOTS" "3/8 W x 1 1/4 DP SLOTS" "1/4 W x 1 1/4 DP CONT SLOT" "3/8 W x 1 1/4 DP CONT SLOT" "3/4 DIA x 2 DP HOLE" "3/8 W x 3/8 DP FALSE JOINT" "MS" "MS EDGE" "MS TOP" "MS BOTTOM" "MS FACE" "MS END" "PITCH" "HONE" "ANTIQUA" "3/8 W x 3/8 DP DRIP" "BULLNOSE" "1/8 x 1 ANCHOR STRAP" "MASONRY LEDGE" "FLASHING" "WEEP AT VERTICAL jOINTS" "PLEASE VERIFY ?" "PLEASE PROVIDE ?" "STUCCO" "CONCRETE" "GYP BD" "BRICK" "CMU" "PLASTER" "CREAM" "INDIANA" "SHELL" "SLOT STOPS HERE" "EASED EDGE" "MARK BACK OF STONE")) (setq dcl_id (load_dialog "CHAN.dcl")) (if (not (new_dialog "CHAN" dcl_id) ) (exit)) (start_list "selections") (mapcar ' add_list NAMES) (end_list) (action_tile "cancel" "(done_dialog) (reset nil)") (action_tile "accept" (strcat "(progn (setq SIZ (atof (get_tile \"selections\")))" " (done_dialog))" ) ) (start_dialog) (unload_dialog dcl_id) (setq SIZ (fix SIZ)) (setq SIZ (nth SIZ NAMES)) (SETVAR "ORTHOMODE" 0) (SETVAR "OSMODE" 512) (SETVAR "DIMTAD" 0) (PRINC "\nSelect 1ST & 2nd point of leader") (COMMAND "_DIM" "_LEADER" PAUSE PAUSE "" SIZ "EXIT") (SETVAR "DIMTAD" 1) (SETVAR "OSMODE" 107) (PRINC) )
Die Zeile (COMMAND "_DIM" "_LEADER" PAUSE PAUSE "" SIZ "EXIT") habe ich schon versucht zu ändern, klappt nicht, weil bei "_qleader" sich die Dialogbox nicht öffnet. Ist es möglich die Lispdatei (Im Anhang mit *.dcl) so zu editieren? Die Links des Autors sind tot. Getestet mit ADT2004 Grüße, Lothar
joern bosse Ehrenmitglied Dipl.-Ing. Vermessung
Beiträge: 1734 Registriert: 11.10.2004 Window 10 ACAD 2021 CIVIL 2021 BricsCAD V14-V22 Intel(R) Core(TM)i5-8250U CPU @ 1.60GHz 1.80 GHz 16.0GB RAM NVIDIA GeForce GTX 1050<P>
erstellt am: 15. Mai. 2006 12:52 <-- editieren / zitieren --> Unities abgeben: Nur für Kramer24
erstellt am: 15. Mai. 2006 12:58 <-- editieren / zitieren --> Unities abgeben:
Theodor Schoenwald Ehrenmitglied
Beiträge: 1672 Registriert: 16.04.2002
erstellt am: 15. Mai. 2006 20:12 <-- editieren / zitieren --> Unities abgeben: Nur für Kramer24
Hallo, nur eine Verständnis-Frage zu dem schönen Tool. Könnte diese Funktion: --------------------------------------------------------- (action_tile "accept" (strcat "(progn (setq SIZ (atof (get_tile \"selections\")))" " (done_dialog))" ) ) ----------------------------------------------------------- auch so: ------------------------------------------------------------ action_tile "accept" "(setq SIZ (atof (get_tile \"selections\")))(done_dialog)" ) ------------------------------------------------------------- aussehen? Gruß Theodor Schönwald Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 16. Mai. 2006 07:31 <-- editieren / zitieren --> Unities abgeben: Nur für Kramer24
Hallo Theodor, ich würde mal sagen ja, das "progn" ist unnötig, weil alle Funktionen innerhalb des STrings nacheinander ausgewertet werden. Und das "strcat" ist hier auch nicht notwendig, das würde vielleicht Sinn machen, wenn man sehr viele Funktionen in dem String unterbringen will (dann ist es übersichtlicher, weil nicht alles in einer ganz langen Zeile steht). ------------------ viele Grüße Jörn Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
