Ok danke fuer die Antwort
Werde die Doku die du empfiehlst auf jeden Fall schmoekern.
Mein Problem ist das Script
Wie heisst der Syntax fuer Demo1/Unterordner1
Dieses wuerde nur je 1 Ordner anlegen (insgesamt 3)
'============================Define Folders to be created============================================
Dim aFolders(3)
aFolders(0) = "Demo 0"
aFolders(1) = "Demo1"
aFolders(2) = "Demo2"
'============================Create New Folders============================================
For i = 0 To UBound(aFolders) Step 1
Set FolderObj = SmSession.ObjectStore.NewObject(FolderClass.ClassId)
'Filling all attributes header to the object's data
FolderObj.AddAllAttributes
'Setting all object's default values
FolderObj.SetDefaultValues
'Setting values to "CN_ID" and "CN_DESCRIPTION"
'Retrieving the mask for the CN_ID attribute and then setting it to the object
Set IDAttribute = FolderClass.Attributes.Item("TDM_ID")
'Retrieving an SmSessionUtil object (Add-In service object)
Set SessionUtil =SmSession.GetService("SmUtil.SmSessionUtil")
'Retrieving the next mask into 'NextVal' and current mask into 'CurValue'
NextVal = SessionUtil.RetrieveNextMask(IDAttribute,CurValue)
'Setting the new mask in the CN_ID
FolderObj.Data.Value("TDM_ID") = NextVal
FolderObj.Data.Value("TDM_DESCRIPTION") = aFolders(i)
FolderObj.Insert
'Link Folder to Desktop
FolderObj.AssignToRootEx WorkObject, 0, LinkObject, RootObject, Behavior
Next
